Question about Samsung Refrigerators
My samsung SR-S73DTA fridge freezer fridge dosnt work freezer does if i defrost it will work for 1 day then stop?
Illeagle
  • 525 Answers
SOURCE: samsung rs20 fridge free
Frost-Free refrigerators have a defrost cycle that they must go through after every several hours of accumulated run time. This is normally done by mechanical means which include a: 1.Defrost timer
2.Terminating thermostat
3.Heating element
Timers are usually 1st to fail. To test the timer you can manually rotate the timer knob to a defrost cycle but then it has to be rotated out manually also. To test the timer, rotate the knob slowly until you hear a distinct click or snap, then stop turning.If the refrigerator is running,(which it should be because it is attempting to cool), it should immediately shut off.
Within a few minutes you should be able be able to hear sizzling noises and/or popping or cracking sounds. If you observe any of these noises, then you have a faulty defrost timer. Allow the heater to remain on for approximately 45 min. to 1 hour, (you may hear water running into you defrost pan under the unit, behind the toe-plate grille), then rotate the knob until the refrigerator comes back on. The unit should then work normally for another few days before you have to repeat the cycle until you replace the timer. If your test is inconclusive, then you will need a technician to do the rest.
Manufacturers locate timers in varying positions depending on design. Usual locations are in:
1. The fresh food compartment, mounted in with or around the cold control,(identifiable by a small knurled knob protruding out of a protective covering). It is usually a small, black, odd-shaped component with the knob on it.
2. Behind the toe plate grille mounted to either side of the frame.
3. On the outside, back wall, inside a rectangular shaped box with the knob protruding through the hole.
If you are unable to locate the timer, then a technician should be contacted for service.
Hope this helps...Let me know if I can be of any more assistance.
Posted on May 25, 2008
  • 3 Answers
SOURCE: Problems with my samsung fridge/freezer SR-L36/SR-L39
is whisker growth like ***** hairs?
Posted on Jun 04, 2008
SOURCE: Samsung SR-L39 fridge freezer switching off
tarsia upatvane
Posted on Aug 30, 2008
  • 5 Answers
SOURCE: samsung fridge rs52530bwp the fridge side will not work
Check the compressor fan and make sure it is working.
Posted on Jun 23, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Posted on Jun 28, 2009
Freezer temp light flashing and freezer and fridge have both defrosted. What the matter with it
Seems like you have Problem in Defrost timer (fixed near the Compressor or may be on the top back-side of the refrigerator). Replace it, problem will be solved.
Oct 02, 2015 | Samsung Refrigerators
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Jun 28, 2009 | Refrigerators
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Location of defrost timer and thermostat in Samsung SR39NXB
Could you kindly tell me how to open this pictured section of the fridge ? Is it inside the freezer section ?
Thanks.
Mar 23, 2009 | Samsung Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
71 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
