Question about Fujitsu 36CS Air Conditioner
Fujitsu outdoor unit not working
There was a wreck with a gas truck and a train about 4days ago and it mest up some power lines down the road from us. We think that when it exploded there was a power surge or something because our unit now will not work. The timer indicator light flashes 3 times about every 30sec on the indoor unit. The indoor unit is set on cool and the fan is on auto. The indoor fan is running but the condenser isnt doing anything. Could this have something to do with the timer light flashing.
    Problem Solver:
  • 10 Answers
Its possible there has been a power spike and it has dammaged the power pcb. Remove the cover and inpect the PCB's for blackening. If any blakening replace the damaged PCB.
Posted on Jul 15, 2010
I have a trouble with fujitsu outdoor model AOY30LMAW4,indoor run but outdoor dont work,every sensor,board is ok,and i dont know how to do next,help me please !! Thanks so much
THE UNIT HAS TO HAVE 2 DIFFERENT VOLTAGES TO RUN.. 24 VOLTS FROM THE THERMOSTAT TO THE CONTACTOR MUST BE PRESENT. REGULAR LINE VOLTAGE TO THE CONTACTOR. FROM THE FUSEBOX OR THE DISCONNECT
May 05, 2015 | Fujitsu Heating & Cooling
How to fix Fujitsu a1 error code for 15rls2 heat pump.
Try cutting power to the indoor and outdoor units for a couple of minutes. Restore power and see if the error returns. The A1 error for this line of units indicates high compressor discharge temperature, which translates to overheating outdoor unit.
If this error code remains after a hard power reset, it's time to pick up the phone. Either you have a refrigerant leak which has resulted in a loss of freon, or a blockage in the refrigerant plumbing that is backing up pressure in the system. Both conditions will require a major repair by an authorized service tech to get your heat pump up and running again. 25361378-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Please mark my answer as helpful.
Jan 09, 2015 | Fujitsu 15RLS2 Halcyon Wall Heat Pump Air...
2004 Chevy trailblazer indecater light on dash are not on and service four wheel drive light is on only have my specker works for the radio and the four wheel drive will not engage. But started my...
Elizabeth: It could be the power train module. This is a computer that tells the drive train everything (like what gear to be in and how much gas to add). Part of the power train module goes to your dash lights. It is usually located underneath the center console, or under the driver's seat or sometimes under another seat. You can go to the wrecking yard, get one that is for your trailblazer and try that.
Nov 15, 2014 | 2004 Chevrolet TrailBlazer
GE airconditioner is not cool, outdoor unit is not working.
Does the compressor relay pull in on a call for cooling? Is there voltage at the relay coil? What type of thermostat do you have? Can you jump R to Y on the t-stat subbase? If you can do that and the compressor relay pulls in then replace the t-stat.
May 24, 2012 | Fujitsu 24C1 Air Conditioner
I installed a fujitsu asu24c1 unit in my garage a few years ago. I used it for one summer, didn't turn it on last summer and when I turned it on this year it wouldn't cool. I have troubleshooted...
With the limited information i would suggest the following:
Check to see if the outdoor unit is running.
If the outdoor unit is running, grab the large copper line coming out of it and see if it is cool.
If the fan outside is running and the line is not cool then the compressor is not running or the system has lost its refrigerant charge.
Check these things and repost for a more complete answer.
Hope this helps.
Sep 05, 2011 | Heating & Cooling
Hi I have a problem with my Fujitsu wall mounted air conditioner ,model AST24RGB-W the outdoor unit fan is running but there is no cold air coming out from the inside unit I put it on high cool to get cold...
I think, your compressor is not working. Check with amphs meter. If less amphs gas leak. Arrest the leak and re charge gas. If tripping with high amphs change capacitor. Still high amps, compressor is defective.
Dec 26, 2010 | Fujitsu Heating & Cooling
Frost on the return line why??
dear sir
please make sure your air conditioner,s outdoor unit,s fan is working if its working and unit is well clean then it can be low freon gas problem ,
please refill freon gas there (if you know how to fill gas )
if don,t know then try to contact to a trained technician for further action .
hope answer the question
thank you
please vote!
Sep 16, 2010 | Mitsubishi MSZ09UN Air Conditioner
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Jun 01, 2009 | Fujitsu Heating & Cooling
Fujitsu 36CS Air Conditioner Logo
593 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
