SOURCE: Power Cord for Creature II
I looked and the only thing I could come up with is to e-mail JBL and order a new one. Radio shack, Best Buy, or Futurehsop might be able to help but you have to call them with the model number or go to the store and check it out. Here's the link to JBL if you want to order a new one.
http://www.harmanaudio.com/search_browse/partlist.asp?BrandId=JBL&MarketId=HOM&Parts=CREATUREIIBLK/230
Sorry, wish I had a better answer but there isn't much out there for this.
SOURCE: My left JBL Creature II speaker has a green light
I had the same issue and applied ezimme solution from Jan 04, 2009 and it worked perfectly. Thanks ezimme!
SOURCE: JBL Creature Speakers
I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
I hope this works for you.
SOURCE: JBL Creature 2.1 Left Speaker not working
Hiya
Too late to resolve the original poster's worries, I can assume, but I arrived here when searching on account of the same problem and resolved it. This is going to sound implausibly condescending, I'm afraid (and excuse th elack of technical terminology!)...
I couldn't get my left speaker to work exactly as above, but then looked carefully at the shape of the respective cables leading to the sub. You have to fit the triangle shape of the lead into the triangular shape of the hole. The speaker CAN be connected what *feels* like correctly, but is in fact connected incorrectly (ie, not all the way in).
This is more a problem with the left speaker than the right since it's a triangle and the right is a square, and can be a little fiddly.
Anyone else experiencing the same problem should probably take a quick moment just to check this isn't it! :)
SOURCE: I have a JBL Creature
I thought my speakers had blown out and they were fixed by just pushing on the black circle inside. The speaker had come loose from the housing- possibly when they fell down or something. Try that before you give up all hope.
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer
speaker system designed and sold by JBL. The system is made up of two
satellite speakers and an omni-directional subwoofer. The speaker system
connects directly to a computer's available sound card output jack or a
laptop's stereo output jack. Occasionally, problems can occur with the
sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable
connections. Ensure the satellite speakers are firmly connected to the
matching jacks on the back of the Creature's subwoofer. The
connections are color coded and, in addition, each speaker connector is
shaped differently to fit only into one jack. Ensure the output cable is
firmly connected to the subwoofer audio in jack and the computer's
audio-out jack. Ensure the power button on the back of the subwoofer is
pushed inward. If everything is connected properly, the green lights
on the underside of the satellite speakers will glow.If there is
still no sound, tap the right-hand side audio-increase button on the
right satellite speaker until sound is heard. Also ensure there is audio
playing from the computer. Double check the lower right-hand side of
the window's main screen and look for a speaker icon. If the icon has a
red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
