Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washing machine won't spin...
I have a GLTF2940ES3 front loader. It is a bit over a year old. Today we went to take the clothes out and they were soaked. We tried running drain/spin, rinse/spin...nothing. It does everything except the high speed spin. Water drains fine..."whirring" noise when it should be spinning....we tried lessening the load too, and nothing. Please help!?!?!? I have a GLTF2940ES3 front loader. It is a little over a year old. Today we went to take the clothes out and they were soaked. We tried running drain/spin, rinse/spin...nothing. It does everything except the high speed spin. Water drains fine..."whirring" noise when it should be spinning....we tried lessening the load too, and nothing. Please help!!!!!!!!!
  • 3 more comments
  • charlenera Oct 22, 2008
    I have too have a GLTF2940ES3 front loader. It is 2 years old. Today we I took the clothes out and they were soaked. I tried running drain/spin, rinse/spin...nothing. It does everything except the high speed spin. Water drains fine..."whirring" noise when it should be spinning....we tried lessening the load too, and nothing. Please help!?!?!? and email me THANK YOU!!
  • Anonymous Dec 08, 2008
    I have a 3 year old GLTF294OES Front Load Washer and noticed that the washer did not drain. I tired the drain/spin cycle, the water drained, but the drum did not spin. I removed the clothes and wrung them out. The drum will not manually spin. I noticed a sock wedged between the inner and outer drum. After removing the top panel, there appears to be no easy way to access the sock. Any suggestions?
  • sglenna Dec 12, 2008
    I have the same problem that sometimes my clothes will finish the cycle and still be very wet. I have also tried to drain and spin or rinse and spin and it doesn't help. Mine is a not even a year old.
  • tvong77 Jan 18, 2009
    the spin cycle won't spin, clothes still wet. can anyone help with this problem.
    frigidaire front load model LTF2140F50 about 1 year old
  • nathan Dec 10, 2012
    we too have a problem, but it makes that loud buzz sound, it kinda starts spinning then stops....wud that be the motor that needs replacement?
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Posted on Dec 28, 2010
I have had nothing but problems with this washer since purchasing it 2 years ago. NEVER AGAIN will I purchase a front loader or frigidaire. Once again, I went to put my wash in the dryer and its soaking wet, won't spin. This is the biggest piece of junk ever!
Posted on Jul 21, 2009
  • Debbie Oct 01, 2011
    I agree with you, nothing but problems, I had better use from my old machine, (top loader)
My washer keeps showing a E20 code...What is this? I read other answers and it seems to be the hoses are clogged or something how do I get inside to remove the sock or what ever it is in it, to fix it?
Posted on Aug 02, 2009
  • smokem_cna Apr 30, 2011
    i had the same error code & the hot & cold where hooked up wrong & the washer would run just not spin
    I am having the same problem (E20) What to do?,,Now it won't even wash, spin or rinse...
Put washer on spin only
press start
press cancel twice
press and hold options and start button until all the lights flash.
turn the knob clockwise 6x
this will override the computer and put it into spin cycle. i have to do this every time until the repair guy comes to repair the comptuer (for the 3rd time) not under warrantee this time.
Posted on Jul 09, 2011
  • Melissa Jacobson Oct 08, 2011
    I tried this - while all the lights flashed several times, when I turned the knob 6 times it goes to silk which is a no spin option. So wondering if this answer is a joke? Ha Ha.
I have the same problem o with this machine, technician came in and replace computer board and motor, for nothing after installing these 2 parts he found that the problem is the lock...as was described by frigidaire technical support.
Posted on Nov 02, 2008
I have an LTF 2940, have a error code 41, which a chart I found says the circuit board thinks the door is open. This is only a page out of a book showing error codes. It recommends running test #7. What's that?
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Oct 01, 2010
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire front loader washer won't go into spin cycle after the clothes are washed
Sounds like you need a technician to diagnose the timer of the unit. Also the sensor that communicates to the timer.
Aug 12, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES3
I believe E47 is a door lock code.
You probably just need to replace the door latch.
Common problem with those units.
Sep 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
My washer wont spin
Frigidaire front loader model # GLTF2940ES3.
Cycle ended prior to spin segment. Checked error code history to find E47 fault. Troubleshot per manual. Found that the "PTC one-spot check" read ~1582ohms. Although the book indicates that this is sufficient and recommends (rather tells) you to replace the control board we were still skeptical seeing as this is a ONE POINT check on a device that is non-linear. We went with the lesser of two evils. Purchased and replaced a new door lock. Works again! Phew, that could have been costly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
9,626 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
