Question about Denon DVD-3910 DVD Player
No picture output
Hello
The lights on the front panel of the Denon 3910 disappear after about 2 seconds and reappear when any button is pushed on the remote or dvd itself. The dvd appears to be playing but there is no output/ picture visible on the tv.
Thanx
Sorem.
  • 374 Answers
Have there been any changes to the systems configuration? Has there been an electrical outage or lightning strike in your area? If the answer to these are no then check the video connection to the tv ensuring both ends are secure in their ports.Ensure the tv is on the right input source for the type you are using. I know this may all seem trivial but sometimes the obvious is the easiest solution. I am assuming you have audio but no video. If you are still unable to make a picture on that tv try another one to isolate the fac t that it is the dvd player itself that is faulty.
Posted on Sep 02, 2008
Denon DRA397 Panel lock on.
Denon has for some reason removed this function from their user manuals. However The manual does show how to do a manual reset of the unit. This may correct the issue.
With the Amp OFF but plugged in, press and hold the speaker A and B buttons and while still holding them press the POWER button. Continue to hold the speaker buttons for another second or so. The display should all light up and flash at 1-second intervals. If not flashing, try again.
This should reset the unit back to factory state with the front panel lock disabled.
Jul 07, 2009 | Denon DRA-397
OSD Locked
1. replaced the control panel micro switchs.
2. press the menu switch 15 secunds.
Nov 29, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
System: DENON AVR 3803 The TV is connected to the receiver, so both the audio and video components are fed through the receiver, I think. The image on the TV was present, but the TV/VCR button was pushed...
THERE ARE ONLY TWO WAYS THE TV SHOULD BE CONNECTED TO THE DENON,
1. MONITOR OUT OF THE DENON TO AN INPUT ON THE TV.
2. AUDIO OUT FROM THE TV TO AN INPUT ON THE DENON.
ALL YOU DEVICES CAN BE CONNECTED TO THE DENON IF #1 CONNECTION IS USED OR ALL DEVICES CONNECTED TO THE TV IF #2 IS USED
Nov 27, 2008 | Denon AVR-3803 Receiver
Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Denon DVD-2910 DVD Player
Dennon 3930 dvd player unable to play sacd in 5 channels only in stereo.will play dvd-a disc in 5 channels
For DENON DVD-3930: In "setup", HDMI sound settings have to be "2-channel". Then SACD 5-channel output is enabled.
Jul 14, 2008 | Denon DVD-3910 DVD Player
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector...
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Jul 03, 2008 | Denon Audio Players & Recorders
I have the Denon AVR-3805 receiver and I can't get it to turn on. When I press the "on" button, it turns from red to green but nothing else lights up. Can you help me?
By now the person who asked this (eleanorr) has certainly solved her problem, but in case anyone else has this same question:
It *is* on, as the color change on the Power button indicator light shows. Most likely, the receiver is fine; it's just that your front-panel display is off!
1. Check the DIMMER mode by pusing the buttom on the front panel -- it may be set to OFF.
2. Push the PURE DIRECT button on the front panel (or remote control) -- it may be ON, which turns off almost all of the front-panel display. (Alternately, change the AV source, which turns Pure Direct OFF.)
Jun 24, 2008 | Denon Audio Players & Recorders
No SACD output
Set the HDMI to "Stereo" from multi-channel.
Mar 26, 2008 | Denon DVD-3910 DVD Player
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
No Audio/Video output with DVDs
lost dvd picture and menu screen through denon av2307 composite conection
Aug 26, 2007 | Denon DVD-3910 DVD Player
Denon DVD-3910 DVD Player Logo
130 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
