Question about Car Audio & Video
Audiophase CA-813 output specs and wiring suggestions
Hi!
I need to know the max output, watts and ohms, that an audiophase CA-813 car stereo can put out.
I need the Ohms because I intend to install 6 speakers instead of the original 4. This brings me to another question:
How would I wire this? I've got one set of infinity 552i speakers 4 ohms, one set of Fei Lo (cheap chinese?) YD140-A1 speakers 8 ohms, and one set of kenwood t10-0286-03 woofers 8 ohm.
should they be run with the infinity's on front channel with Fei Lo and the Woofers in parallel on the rear channel??
I know this is a strange mish mash of cheap ****, but cheap is what I've already got on hand.
Shuttle83
  • 1139 Answers
SOURCE: speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Posted on Oct 09, 2007
Cerfer39
  • 709 Answers
SOURCE: Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Posted on Oct 13, 2007
SOURCE: Wiring for running 4 speakers from amplifier
I asked about wiring up 4 speakers from oe amplifier....not about Tom Tom?
It does not inspire me with confidence in your abilities if you get confused between customers and their questions, so I will look elsewhere for answers.
Thanks anyway
Posted on Jul 04, 2008
easyq
  • 144 Answers
SOURCE: With my RX-V663 can I use presence speakers less than 8 ohms?
Basically you can use any speaker as long as you use the volume button wisely. Damage will only occur if you raise the volume level to the extremes. Bigger speakers should be no problem, if you want bi-amping, your speakers should support that as well.
Posted on Apr 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Posted on May 19, 2009
My friend just got a KOLE AUDIO QX1-30000.. he's wantin to know if its a 3,000 watt amp or what because it says QX1-30000 on it??
This is the specs on it:
  • RMS Power Rating:
    • 4 ohms: 1100 watts x 1 chan.
    • 2 ohms: 1800 watts x 1 chan.
    • 1 ohm: 2300 watts x 1 chan.
  • Max power output: 3000 watts x 1 chan.
Jul 01, 2015 | Kole audio Car Audio & Video
What is the watts
Hi.
The Jensen XS-1010 is a 450-Watt 10" (450W peak, 150W RMS ) Subwoofer.
Below the full technical specifications:
Tech Specs
Product Type - Car subwoofer driver
Dimensions (WxDxH) / Weight - Car subwoofer driver : 4.7 in Diameter 10.1 in
Dimensions - Diameter - 10.1 in
Enclosure Color - Blue
Localization - English
Speaker Type - Passive
Speaker Diameter - 10"
Nominal (RMS) Output Power - 150 Watt
Max (RMS) Output Power - 450 Watt
Response Bandwidth - 24 - 1000 Hz
Input Impedance - 4 Ohm
Output Level (SPL) - 88 dB
Connectivity Technology - Wired
Speakers Included - Car subwoofer driver - 10" - 150 Watt - 24 - 1000 Hz - 4 Ohm - wired
Driver Details - Car subwoofer driver : 1 x subwoofer driver - 10" - polypropylene - Mid-Q
Diameter - 9 in
Depth - 4.4 in
Sep 07, 2011 | Jensen XS-1010 Car Subwoofer
Will i be able to swap the original speakers of the J520 with a pair of Sony SS-B1000, without causing damage to the new speakers? the Sony SS-B1000 has an Impedance of 8 ohms, and peak power of 120 watts.
Hi, As long as you like the way the speakers sound there is really no reason you cant use whatever speakers you want. To find out the approximate wattage of the stereo you are using look on the rear of the unit and you will find a tag that has " SPECIFICATIONS " on it. There you will see perhaps the a.m. and f.m. frequencies it's capable of receiving also there should be numbers saying something like" 100-240vac or 100-240v~ 50-60hz 1.2amp or 120watts.( if power is listed in amps only-1 amp's equivalent to about a hundred watts)Dividing the wattage by 3 will give you an approximate power out put. Example if your stereo draws 120 watts worth of 110 from the wall it will put out approximately 40 watts to each speaker. Changing from OEM speakers is all right as long as you don't try to hook up some 150 watt peak speaker to a stereo capable of just, say, 10 watts per channel. Doing this will eventually cause damage to the amplifier, not to mention causing about 30 percent total harmonic distortion-which take my word for you will know if you ever hear it! So long story short-use what you wish, just be careful not to overload the receiver-if the speakers are a bit to powerful for receiver you can lessen distortion by turning down the " BASS" as that takes the most power in a speaker. Thanks for choosing FixYa, I hope this helped-good luck, Prodzilla
Apr 15, 2011 | Audiophase J520 CD Shelf System
A3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Brocken Audiophase CA-813 stereo plate
    if your talking about the face of the radio then you'll have to take it to a car audio place and get them to send it away, if you want a new one then you'll have to spend afew more bucks , a new one ( I heard) is about $100
    Jun 18, 2009 | Car Audio & Video
    Best results
    huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
    1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
    2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
    3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
    Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
    Audiophase kz112 problems
    Someone made another post about the kz112 being recalled? I would check into it
    Dec 31, 2007 | Audiophase MDP-1 Personal MiniDisc Player
    Users Manual for a Adiophase CA-813 Automobile Radio/CD Player
    i have an audiophase dm9804 cd player. i can't change tracks. help!
    Dec 27, 2007 | Audiophase MDP-1 Personal MiniDisc Player
    Speakers
    Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
    Car Audio & Video Logo
    167 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
