Philips DVP3140/37 DivX player does not play certain DivX files. I have the region code as 0. For some DivX files it plays the video but the audio does not work. These work fine on computers.
  • Anonymous Nov 18, 2008
    Same problem,
    But my player will not bring up the version when I press "3+7" on the remote.
Have you tried upgrading the firmware.
Check first the firmware of your DVD by opening the tray, then press 37 on the remote, and jot down the version of the firmware, then try to find an upgrade to your version or an improvement to it that fixes the original trouble with some DivX files.
Posted on Sep 02, 2008
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
Can i play Xvid files on my 622 dvd player? if not which kind of video files does it play?
Im assuming your talking about the Philips DVD 622. You cannot play any video files unless they are burned to a CD or DVD in the standard DVD format. It can play certain audio formats but cannot play different video formats.
Jul 24, 2009 | Philips Televison & Video
Does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Apr 08, 2009 | Philips DCP851 Portable DVD Player
This model cannot play real player video files your model work on DVD, CD, and on the following compressed file formats:
Compression formats - MPEG1 , MPEG2 , DivX 3.11 , DivX 4.x , DivX 5.x , DivX 6.0
Your player can play only mpeg , avi , and divx, not real player .rm files. I don't think there are many DVD that can play real player files around.
Dec 22, 2008 | Philips DVP5140 DVD Player
Does not play DVD with all region
"Region-Free" is not the same as "Region All" - the "Region All" discs are extremely hard-to-find.
There is not a USB port on this DVD player, so it will not play those files from a USB drive. It will, however, play those file types if they are burned onto a DVD Video disc, or Audio CD. It will not play Data DVD's or CD's.
-Tha Mp3 Doctor
Jul 27, 2008 | Philips DVDR3505/37 DVD Recorder
I have a Philips DVD Player DVP3960 1080i HDMI DivX DVP3960/37 and I need a code to unlock in my system to play multi region.. Thank you
Press "Setup"
Scroll to "Preference" using the Left/Right arrow key
Press "138931" and a popup screen will appear
Use the Up arrow key and select 0 for a region free DVD player
Jul 18, 2008 | Televison & Video
DVD Rejion problem
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Jul 07, 2008 | Yamaha DVR-S120 DVD Player
How do I play MPEG recordings?
Using Windows Media Player You need Microsoft Windows Media Player Version 9 or higher and Sharp G.726 Audio Codec in order to play MPEG4 files from the Memory Stick on your PC. If you are not currently using Microsoft Windows Media Player Version 9 or higher. Important: The Sharp G.726 Audio Codec needed to play MPEG4 files is no longer signed by Microsoft. If Sharp G.726 Audio Codec is not properly installed on your PC, it will not play MPEG4 Audio. Using DivX® You can also download a free DivX® Player and codec to play your MPEG and other video format files. DivX® for Windows is a free codec built to play every version of DivX content. The DivX codec also plugs into your existing video software so you can view and create high-quality DivX videos at a fraction of the original size. The DivX codec also adds DivX video playback support to most popular media players.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
534 people viewed this question
Top Televison & Video Experts
