Question about Sony Mavica MVC-FD95 Digital Camera
FD-95 port?? Can someone tell me what the white colored port is behind a plastic cover on the back lower right corner of the FD-95 is. ??
    Master:
  • 551 Answers
Yes, the small white connector on the camera is the programming and diagnostic port for the camera. We connect a diagnostic connector to this for reading the state of the internal electronics. Upgrades, when needed are done through the port.
Posted on Sep 13, 2005
Muratec MFX-2830 with call service :0C
0C means you have a cooling fan problem. Located behind the lower rear cover in the lower right hand corner of the machine. Either the filter has gotten caught in the fan "OR" the fan itself has gone faulty..."it is also a signal generator." So...check for the filter caught; or the fan may have to be replaced.
Aug 09, 2010 | Muratec MFX-2830 Black and White Copier
Electrical cord was accidentally pulled out of ac unit.
Green is ground, secure to frame. White goes to compressor, located behind LED/LCD, lower right corner you'll see a number of other colored wires kind of in a circle, each connected to a 'port'. The black goes behind LED/LCD panel also. Top far right, back corner. 2 ports are connected to a black box..a red one and should b your black one.
GOOD LUCK!
Jul 13, 2010 | Kenmore 75085 Air Conditioner
How do you remove inner tub to get to the outer tub of Fisher & Paykel gwl11
You need 2 people for this.. Unscrew plastic wingnut down the centre of the agitator.(2) undo 2 phillips head screws under little rubber covers just under lid at front top edge.(3)lift top of machine like a car bonnet,get someone to hold it up for you.(4)Unclip big round plastic ring on top of the bowl,you may find its attached with a spring at the front left hand corner,just lay the plastic ring over front of machine & let it hang.The bowl should just lift straight out.Be carefull,the outside of the metal bowl is like a cheese greater trust me! PS when you put it back together & you lower the top of the machine(make sure that little white plastic lever hanging down) the right hand rear go's outside the righthand rear of the tub NOT squashed on top.Its an out of balance lever & it needs to dangle outside of the bowl/tub right rear.GOOD LUCK!
May 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Knocking sound in upper left of refrigerator.
Yes, there is a ventilator (fan) for recirculating air. Looks like needs some maintenance (bearings regreased/oiled) or, if the worn is too high and blades are disbalanced, a new one.
Sep 11, 2017 | GE GSS25JEMCC Side by Side
I have a magic chef compact refrigerator model mcbr445b1 wont turn on dont remember how to reset it with red button on temperture dial
Sounds like defrost timer on back right corner has stopped in the defrost position. Located bottom left corner inside white plastic box if you are behind ref.
Feb 01, 2010 | Refrigerators
1990 TOYOTA CAMRY-DASHBOARD ICON IN LOWER RIGHT HAND CORNER
Its telling you a brake light bulb is burnt out.
If you find that all the rear brake bulbs are working...the problem is the sensor, located in the trunk, left side, behind the left side plastic wall (Removeable). It is a 2 X 2 cream colored box. Dealer only part. $80-$100 each. Have known 6 other Camry's to have a bad sensor box. Common problem.
Jun 24, 2009 | 1990 Toyota Camry
How to Access Color Wheel on Toshiba 46HM95
I bought a used 46hm95 but it had a greenish "band" that streched from the upper right corner to the lower left corner. It was only noticeable on a white or light colored background, which is why I overlooked it when I tested out the TV.
I took out the bulb and shined a flashlight into the color wheel. I could see a fingerprint smudge on it. I took off the lower rear plastic panel. the rear is split into two section (the light engine is on the right. You'll have to unscrew a metal guard (three scerws), then disconnect the wires coming from the left section, and then unscrew the plastic guard that protects the lens. Then unscrew the light engine (two screws) and slide it out carefully (you don't have to take it completely out, just far enough to reach the screws to the color wheel covers). There are two covers protecting the color wheel, one plastic and one metal. Unscrew the plastic cover first than the four screws to the metal cover. I left the color wheel in place while I cleaned it with a microfiber cloth. I did pull the glass square in front of the color wheel and wiped that down too.
I put everything back together, and now the picture is perfect.
Things to remember are:
*Keep track of the screws and where they belong, as you remove them so you'll remember where they go when it's time to put things back together.
*Mark the wire connectors from any wire you disconnect in case you forget where they go.
*Be gentle with the color wheel and the glass square because they are fragile.
Hope this helps.
Sep 25, 2008 | Toshiba 46HM95 46" HDTV
Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
HP 3500 color printer
If you can see what is stopping the door from closing, and it appears to be on the right side of the printer near the top where the cartridge engaging pins are, and you remove all the cartridges and transfer belt and the door closes well, you may want to try this: There is a small silver screw at the top of the right corner of the case. When our front door would not close properly with the cartridges and transfer belt assembly installed, I took off the right side cover and took out that top corner screw. Then I slid the long white engaging rack that is on the lower right side of the printer toward the front door, which retracted those cartridge pins that are triangularly-shaped on their ends. Once the door would close properly with the cartridges and the transfer belt installed,and the pins engaged properly to open the cartridges as the door closed, I put the top corner screw back in and the side cover back on. I hope that helps you.
Sep 17, 2007 | HP Color LaserJet 3500 Printer
Sony Mavica MVC-FD95 Digital Camera Logo
51 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
