Question about HP Office Equipment & Supplies
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the problem. The printer merely takes a piece of paper and passes it straight through without any printing and gives the "Carriage jam" message again. I cannot find any instructions in the Basics Guide. Please help.
  • HP Master
  • 1,879 Answers
Just check for any obstructions inside the unit, if all is clear and it is still giving you the same error, it's time for service or replacement (if warranty permits).
Posted on Sep 02, 2008
    Genius:
  • 1,142 Answers
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
  • 9 more comments
  • Maanita Chadha
    Maanita Chadha Sep 02, 2008
    To clear a paper jam from the rear door, complete the following steps.
    1. Press in the tab on the left side of the rear door to release the door. Remove the
      door by pulling it away from the product.
      Figure 1: Removing the door
    2. Gently pull the paper out of the rollers.
      CAUTION:
      If the paper tears when you are removing it from the rollers, check
      the rollers and wheels for torn pieces of paper that might be remaining inside
      the product. If you do not remove all the pieces of paper from the product,
      more paper jams are likely to occur.
    3. Replace the rear door. Gently push the door forward until it snaps into place.
      Figure 2: Replacing the rear door
    4. Press the button next to OK to continue the current job.
  • Maanita Chadha
    Follow these steps to make sure that the print carriage can move freely.
    1. Unplug the power cord from the back of the product.
    2. Check whether the print carriage is moving freely from one side of the product to the other.
      If
      it does not move freely, apply a moderate amount of pressure to the
      right side of the print carriage and push it towards the left.
      This action should not require the use of any levers.
      If the carriage still does not move freely, skip to the next step
  • Maanita Chadha
    1. Close the print cartridge door.
    2. Plug the power cord into the back of the product.
    3. Press the
      Power
      button on the front panel to turn on the product.
  • Maanita Chadha
    1. Make sure that you are using the power cord provided with the product.
    2. If the product is connected to a computer, make sure the computer has a
      grounded (three-prong) power plug.
    3. Make sure the power cord is firmly connected to both the product and the power
      adaptor.
    4. Plug the power cord directly into a power outlet.
  • Maanita Chadha
    1. Remove all paper loaded in the input tray.
    2. Make sure that the product is turned on and remove the USB cable from the back
      of the product.
    3. Open the print cartridge door. The print carriage should move to the far right side of the product.
  • Maanita Chadha
    1. Remove the print cartridges and carefully set them aside.
    2. Close the print cartridge door.
    3. Disconnect the power cord from the product and wait for 60 seconds.
    4. Reconnect the power cord to the product.
    5. Turn on the product by pressing the
      On
      button.
    6. Open the print cartridge door. The print carriage should move to the far right side of the product.
    7. Reinsert the print cartridges in the appropriate slots.
    8. Close the print cartridge door.
    9. Load paper in the input tray.
    10. If prompted, print a cartridge calibration page, and then scan it.
  • Maanita Chadha
    1. Make sure the product is turned on.
      CAUTION:
      If the product is turned off when you open the print cartridge door to
      access the print cartridges, it will not release the cartridges for changing. You
      might damage the product if the print cartridges are not docked safely when you
      try to remove them.
    2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  • Maanita Chadha
    1. Wait until the print carriage is idle and silent.
    2. Lightly press down on a print cartridge
      to release it, and then pull the print cartridge toward you out of its slot.
  • Maanita Chadha
    1. Hold the print cartridge with the HP logo on top, and insert the print cartridge into
      the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
      into place.
  • Maanita Chadha
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
  • Maanita Chadha
    PLEASE REFER TO THE LINK FOR FURTHER INFO
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Genius:
  • 3,422 Answers
HI,
Please click on the below link and follow the steps mentioned to clear carriage jam.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01309787&cc=us&lc=en&dlc=en&product=3192753
  • Priya darshan Sep 02, 2008
    Please don't forget to accept the solution as fixya.
    Sergeant:
  • 241 Answers
HI I would suggest that you turn off the Machine and remove the INK CARTDRIDGE.
And then PUT it back in and START IT UP this should work
  • Jayson Brollini
    Jayson Brollini Sep 02, 2008
    YOUR PRINT WILL ASK if this is a NEW OR USED ink
    USED and the PART number may be asked too.
    If this Helps Please
    Rate the Advise from FixYa ExpertKindofcheap
HP Printer C4280 says "USB not connected"
Install software that is twain compliant.
Maybe the HP bundle that came with the printer.
Also Paint Shop Pro,Adobe Acrobat.Photoshop etc.
Use the usb cable after the install of the HP drivers then you may change the default location of where scans are saved.
Jul 21, 2009 | HP Photosmart C4280 Aio Printer
Paper jammed while printing
took printer back to Staples after HP refused to help. They fixed it and showed me how to do it in the future. Thank you Staples
Mar 22, 2009 | HP PhotoSmart C4280 Laser Printer
HP Photosmart C4280 will not print text
I resolved this by going to "tools" -> "Clean Print Head".
Dec 14, 2008 | HP Photosmart C4280 Aio Printer
Can only print on the printer's copy
sir try uninstalling the whole old printer program on the add/remove icon on the control panel... then reinstall the software again... this is because in the process of installing the printer the software is scanning the installed printer... is not because you have the same unit as before they are one same unit... i mean they still differ on parts model and serial numbers so the OS still need to recognize the new printer installed...
hope this helps...
Aug 18, 2007 | HP Photosmart C4280 Aio Printer
220 people viewed this question
Seeker5211
Seeker5211
