Question about Kodak EasyShare CX7525 Digital Camera
Kodak easyshare program for vista premium - Kodak EasyShare CX7525 Digital Camera
Get the XP "Upgrade" for Vista
Posted on Oct 18, 2008
4 Suggested Answers
  • 2692 Answers
SOURCE: Kodak Easyshare software stops working immediately after starting
Are you sure that the softweare you attempting to install isd for the VISTA os? If not go to the support page and dowenload the correct software drivers.
http://search.kodak.com/?pq-locale=en_US&global=en&q=c613
Posted on Jan 04, 2009
RattMur
  • 53 Answers
SOURCE: Vista knocks off Kodak easyShare C613 Program
I have a problem with Vista too, but it will just slow the whole system down, even when it's not running. Look up "paint.net" on download.com. That is the editing software I use.
Posted on Jan 16, 2009
SOURCE: Kodak Easyshare Software has stopped working
I was getting the message "Kodak easyshare software has stopped working" and couldn't find any forum with an answer. I called customer support and they were able to help me. I was running Vista 64 bit. And apparently the default installation installs in under the "c:\Program Files (x86)\" folder instead of the "c:\Program Files\" folder. They had me uninstall the software then create the folder "Kodak" under "c:\Program Files\". They also had me delete the "Kodak" folder under "c:\Program Files (x86)\" which I had trouble doing. I ended up having to go down in that directory and delete some of the files individually. In the end they said it was okay to leave a few files there. I then reinstalled the software - using custom settings and selected the "c:\Program Files\Kodak\" folder to install. After restarting it worked. This is a pretty simply error in the software that the programmers should have fixed. Fortunately the help people were helpful!
Posted on Mar 02, 2011
Windows vista wont allow Kodak G600 printer to print pictures using easyshare program
Hi lomls3,
Are you using Kodak Easyshare ver8? If not, you may need to update the software in order for Vista to send the print jobs to the Kodak G600 printer.
Update the software to ver 8 first. Reboot the computer and retry printing.
Ver 8 can be downloaded here: http://www.opendrivers.com/driver/293165/kodak-digital-camera-kodak-easyshare-software-update-8.0-windows-2000-xp-vista-win7-free-download.html
Hope this helps.
Andrew
Apr 04, 2010 | Kodak Easyshare G600 (1633379) Dock /...
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Jan 15, 2009 | Kodak EasyShare C633 Digital Camera
Dec 29, 2008 | Kodak EasyShare C613 Digital Camera
Can't get picture to scan
try doing this procedure to fix the issue.....
To perform a clean installation of the KODAK AiO Home Center software, follow the instructions below:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the KODAK All-in-One Printer Software:
    a. In the Control Panel, select Add or Remove Programs (WINDOWS XP Operating Systems) or Program and Features (WINDOWS VISTA Operating Systems).
    b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
      • Kodak EasyShare software
      • KODAK All-in-One Printer Software
      • Kodak EasyShare 5000 series all-in-one software
    c. Click Change or Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA OS).
    d. When the Install Wizard appears, click Next.
    e. Depending on the issue(s) you are experiencing, do the following:
      • If you are experiencing errors with KODAK EASYSHARE Software, such as a tri-code, in addition to errors with KODAK All-in-One Printer Home Center Software, select Remove, click Next, and follow the on-screen instructions for removing the software.
      • If you are not experiencing errors with KODAK EASYSHARE Software, select Modify to uninstall only KODAK All-in-One Printer Home Center Software, then click Next.
    f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
    g. In the Ready to remove the program window, click Next.
    h. In the Uninstall Complete window, click Continue.
    i. Restart the computer.
IMPORTANT:
    • If you selected Modify and only uninstalled the KODAK All-in-One Printer Software and did not uninstall the KODAK EASYSHARE Software, continue to Step 4.
    • If you selected Remove and uninstalled both the KODAK All-in-One Printer Software and KODAK EASYSHARE Software, continue with Step 3.
3. Run the Clear Utility to delete any previously installed KODAK All-in-One Printer Software components:
    1. Got to www.kodak.com/go/clear to download the Clear Utility for KODAK EASYSHARE Software.
    2. Select your operating system from the drop-down list and click the Download button to save the file to your desktop.
      Note: If the status indicator on the Clear Utility stops, check the taskbar on your computer for an active security program. If a security program appears in the taskbar, it may be prohibiting the Clear Utility from running. You must allow the Clear Utility to run on your computer before you can continue.
4. Delete the files and folders that can interfere with the installation.
    For WINDOWS XP OS, delete:
      • Printer folder in C:\Program Files\Kodak
      • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
      • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
      • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
    For WINDOWS VISTA OS, delete:
      • Eastman Kodak Company folder in C:\ProgramData
      • Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
5. Run Disk Cleanup:
    1. Open My Computer.
    2. Right-click Local Disk (C:) and select Properties.
    3. Click the Disk Cleanup button.
    4. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
    5. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
    6. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
6. Shut down all background applications.
    1. Select Start > Run.
    2. Type msconfig in the Open field, and click OK.
    3. Select the Startup tab.
      IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
    4. Click Disable All , then click OK .
    5. When prompted, restart the computer.
7. After the computer restarts, install the latest version of the KODAK All-in-One Printer Software as a free download from the Kodak Web site at www.kodak.com/go/downloads.
    • If the customer has the latest version of the KODAK All-in-One Printer Software on CD, install the software from the CD.
8. Before restarting the computer again, turn on the background applications.
    2. Type msconfig in the Open field and click OK.
    4. Under Startup Items:
      - If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
      - If all background items were originally selected, click Enable All, and click OK.
9. Restart the computer.
Nov 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Close Easyshare Program > If you see an icon of easyshare at the system tray {lower right corner of the screen}
right click on it and choose Shutdown Easyshare
Right Click on the icon of Easyshare on your desktop{upper left of screen}
choose Properties, choose Open file location> Look for Catalog Folder > rename it to "old catalog" > close the whole window
Go to My Computer > C: Drive > Users > Public > Public Documents >
Look for ESBK.mb and ESBK.mbb
restart your computer
Relaunch Easyshare Program
Goodluck...
Sep 20, 2008 | Kodak EasyShare C613 Digital Camera
Video display with Kodak AiO Home Center
Make sure that your screen resolution is 1024x768
Jun 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Easyshare Software
The 3.0 is no longer available on the website and support is also discontinued on that version. Try downloading the new version 8.0 for xp/vista or 8.1 for win 7 ,make sure that your system meets the minimum requirements of the program, download the program at www.kodak.com/go/edl
Nov 20, 2007 | Kodak EasyShare CX6330 Digital Camera
Kodak EasyShare CX7525 Digital Camera Logo
78 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
