Keyboard not found..
...I know the KB is good, as it/ they work in other PCs...and I do have the connections correct...(even if they were not color coded) I have and/or would have changed their positions...I get a bios report telling "keyboard not found"...I have encountered this situation before...I just disposed of the computers as I cannot find any solution...I have change out the CMOS battery, tried up to 6 working KBs...I unplug the computer(after shutting it down), move it to another room in my house...and the damn thing(s) cannot find the KB's..this has happen to many of my computers...the current system is an..HP KAYAK XM600..."BunnY" tried to help...H/she was wrong...but I offer my thanks...DOES ANYONE HAVE A SUGGESTION/SOLUTION??? thanks you...Fido
    Brigadier General:
  • 5,158 Answers
Well despite the fact you have given up on me when we were attempting to troubleshoot your problem here is one more thing to try and it can't hurt... swap your keyboard to the ps/2 port you use your mouse on and plug your mouse where your keyboard was. the key here is that when you move the computer to another room... you would have to unplug the keyboard and mouse each time. swap them and see what it does.
Robert
Posted on Sep 03, 2008
  • Roberta Smith
    Roberta Smith Sep 03, 2008
    one thing that just did occur to me... does the keyboard connect directly to the computer or are you using wireless to access them ?
    Robert
Keyboard CAPS LOCK light working in reverse
whoever opened up your keyboard messed up with the light cables, open cable and see if you can put back cables in correct connections.
Mar 22, 2014 | Acer KB.T.3007.006 Aspire Keyboard us P/N:...
Broken led brackets in the base section, severed wires from monitor to base. Broken keyboard frame and keyboard. Cooling fan (thermal) damaged and heating up. Framework around the dvd enclosure is...
Id have a look on ebay with you model specs for all sorts of spare parts even broken complete pcs,some pcs have good spare part availability but others are difficult to find--good luck!
Davey Snake!
Oct 23, 2010 | Computers & Internet
Need help replacing keyboard of acer 5536
I found them on ebay in 2 seconds. Ebay usually will have whatever you need. I'm sorry to say that this may not be a fix though. Most likely yes, but possibly not. What exactly is your keyboard doing? You should also know that even though your computer is functioning now, if you do not get the spillage cleaned off the motherboard it will cause the board and whatever components it got on to corrode. It's possible that it may not have gotten into you computer but I doubt it. How bad was the spill? It is also possible, depending on what the keyboard is doing exactly, that you may not need a new KB. It maybe just a good cleaning or cleaning out the KB connector.
Feb 08, 2010 | Acer Aspire 5536-5224 Notebook
The number key does not work even after changed the batteries. And the back space button and some of the keys don't work unless you push hard on them.
Look for dirt or grit under the keys, use a can of compressed air to clean out the keyboard. To use the number pad, you have to ensure that the NumLock button has been turned ON.
If the keys still dont seem to work, remove batteries and type randomly over keyboard for about 20secs. Now reinsert the batteries (ensure correct orientation), and reconnect the KB with dongle by pressing the connect button on dongle first and then on the KB. Make sure there is no source of interference nearby, such as speakers, powerful magnets, etc.
If the KB still does not function properly, uninstall and reinstall the software. Still wont function? KB is defective. Contact Logitech regarding an RMA if within the warranty period.
Cheers!
IrishDruid
Jun 24, 2009 | Logitech Cordless Desktop Wave Keyboard...
Unable to connect Logitech cordless keyboard
Of course you know to press the connection button on the receiver then on the keyboard. Since setPoint is recognizing the connection I wonder do the multimedia and function keys work? Do you have the the USB receiver for the KB/Mouse plugged into a hub or KVM switch? If so plug it directly into the back of the PC. See this KB http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9247
Jun 11, 2009 | Logitech Wave Cordless Desktop
Keyboard not working
This is sort of general but it just may help.
Make sure your batteries are in correctly.
Make sure the transmitter dongle is in the USB.
Look on the transmitter and the mouse and keyboard
itself (bottom) for a little tiny button that says connect
or reconnect. Move the mouse about six inches away from
the transmitter and press both the transmitter and the mouse.
That should reestablish the signal twixt the two.(or three KB)
May 10, 2009 | Logitech Inc Cordless Desktop Express...
I have an iogear usb kva switch connected to two PCs (one desktop; one laptop). It used to work fine with a wireless keyboard (HP), but after I replaced it, it stopped allowing me to switch between PCs...
Hi ther. make sure that you connect them to the correct port. If using a wireless keyboard, connect the receiver to the keyboard port. check underneath for the keyboard icon. Make sure that the receiver is connected to that port.
May 09, 2009 | IOGear GCS632U 2-port KVM Switch
Wireless Multimedia keyboard volume keys won't work.
Go to start and run then type services.msc or if using windows 7 just go to start and type services.msc in the search box. Once open find the service "Human Interface Device Access". Change it from manual to automatic and make sure that it is started.
Apr 04, 2009 | Microsoft Wireless Optical Desktop 1000...
PC won't boot
Is the case speaker connected to the motherboard?
If it is, do you get any beep sequence? If there is no display, the power speaker output an audible beeps sequence. For example, 3 short beeps mean a problem with memory.
Keep posting here to zoom in on the solution.
Dec 28, 2007 | PC Chips A21G Motherboard
Computers & Internet Logo
David Payne
David Payne
