Question about Sony Mavica MVC-FD95 Digital Camera
Mavica FD95 and Sports Photography.
I recently purchased the Sony Mavica FD95. Currently the camera is being used to take alot of sports photos as I cover a local sports team website. Im not an experienced photographer by any means and am not sure of how to adjust many settings to improve some of the photos that I take. I would like to know what settings on the Mavica FD95 could be adjusted to help take better sports and action photos? The main problem that Im having is blurring. I take the photos outside at night under stadium lights at football games. I have been told that adjusting the shutter speed will help with the blurring but when I adjust the shutter speed that most suggest for action shots such as Football games, the Mavica then fades the light to black in the viewfinder and you cant see what you are shooting. I could hardly be called an amature photographer but am trying and any help would be appreciated. Thanks ahead of time!
    Master:
  • 551 Answers
Basically you bought the wrong camera for your needs. The 95 can not do well under the conditions you describe. The ISO is fixed and to low for the amount of light you have available. The viewfinder begins to darken after the lens is wide open and the shutter speed is increased further. There are three possible cures. More light, not possible in your situation, faster lens or higher ISO, again not possible with your camera. Maybe you could convince them to play in the dayight. :)
Posted on Sep 13, 2005
Sony Mavica FD95 Camera
This is a common problem with the Mavica FD95. There is a little switch in the drive slot to sense the write protect tab on the disk.
If you hold open the drive door without a disk in, you should see this switch where the write protect tab goes. Try operating the switch with a matchstick a few dozen times to attemp to clean the contacts. If that doesn't work then Very carefully let a drop of switch cleaner run into the switch and try operating it a few times then let it dry. Failing that you might want to open the camera to get to the terminals on the switch and test it with a multimeter.
If the switch is faulty and a replacement is not availble then you could just short(or disconnect) it to fool the drive into thinking any disk is writable.
Good luck
Oct 19, 2007 | Sony Mavica MVC-FD95 Digital Camera
My digital display is broken, and i was wondering if i could use the display off another. are they compatible
so long as the conectionsr the same then it should i swapped out two diferent laptop screens .same vidio format same plugs no problem
Jan 17, 2010 | Sony Mavica MVC-FD95 Digital Camera
When on sports setting, my camera shoots slow and blurry when indoors
More than likely, your exposure- specifically your shutter speed settings- are too low. When you have fast action, you must have a higher shutter speed (Higher, meaning that the DURATION of the exposure is less. So, an exposure of 1/250th of a second is more desirable than an exposure of 1/30th of a second when shooting indoor sports. (This difference equates to about 400% more exposure, duration-wise). When shooting sports indoors, a "Fast" lens, meaning that the front of the lens is bigger, which allows more light into the camera at one time. (This normally equates to "F-Stop" settings. So, a 50mm F1.4 lens will be a "faster" lens than a 50mm F2 lens. The lower the F number, the "faster" the lens. This also equates to higher prices...) Another consideration for shooting stop-action sports photography indoors is using higher ISO settings. When you double the ISO number, you cut the amount of light required to make a good exposure in half. So, ISO 200 requires half the light of ISO100, and 400 requires half the light of 200 and so on. Typically, I use a setting of ISO 800 or higher for indoor sports (Which, BTW is my speciality...). The trade-off for using higher ISO settings is that it introduces more noise into the image, which many people find less desirable. I also wrote a few articles for POPULAR PHOTOGRAPHY & IMAGING about shooting sports. The "football" article will more than likely be the most help to you. Basically, ALL sports photography is shot the same way, and if you use these techniques, your work will greatly improve. Here is a link to those, and hope they help!
http://www.popphoto.com/Blogs/Sports-Photography
http://www.popphoto.com/Features/Shooting-Talladega-Superspeedway
http://www.popphoto.com/Features/How-to-Photograph-Football
Jul 10, 2009 | Nikon D60 Digital Camera
FD95/memory-what do I need?
You need the MSAC-FD2M Floppy Disk Adapter. It's probably going to be hard to find these days.
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
FD95 flash problem!
The flash doesn't open automatically. There is a button on the side of the camera that says Flash (open).
Mavica FD95 Error Msg C:13:01
A Cxxxx error normally can be fixed by the user. I suggest you remove the battery pack AND the button cell (I suppose the FD95 has one) and leave it without both for at least half an hour. I would think that after that, it should be ok except that you'll have to set the clock and some other preferences again. Hope this helps.
Need Help FD95 Memory Stick
Not all fd 95 are memory stick compatible !
FD95 underwater housing?
2 ziplock bags and alot of duct tape (serious) itll be good down to about 10-20meters. It's limited use, but it works.
Mavica FD95 Flash Quit Working???
My flash went out twice on my FD-95. The first time it was fixed under warranty and it was the bulb. This time I haven't fixed since I have my 707 now. It still works with the external flash like yours did before you dropped it. If possible I would try and buy another external flash since your time is short. When I had my camera fixed under warranty it was just about to run out and they, the camera shop, told me I should get it fixed now instead of out of warranty because the cost could be hundreds just in labor alone. Good luck.
Sony Mavica MVC-FD95 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
