Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox 51MP392H/17 No pic only sound
Have Magnavox 51MP392H/17 first the pic started to flicker every once in awhile, no no pic and only sound. Menu letters wont show either. Any Idea's? Thanks, Tim
  • winwithrose Sep 20, 2008
    I was watching tv then there was a popping sound like a light bulb dropped. Then the picture was gone, I still had sound though.
    Genius:
  • 1,139 Answers
Hello winwithrose,
The popping sound may have been a capacitor. The chance are the capacitor is in the HV section of the TV set and is part of the supply to the Horizontal section of the TV. First if you do not have electronics experience I would suggest you take the TV to a qualified TV repair shop. OK now if you have electronics experience I would say to unplug the TV, open the set up and do a physical inspection of the TV you will be looking for a capacitor that has exploded; if you find one look at the schematic for the TV and find its value. Then do so checks to find out why did the capacitor explode. Most likely the capacitor exploded because of wear and tear, but it always pays to check. Replace the capacitor with one of the same value and then turn the TV on, use your voltmeter to measure the voltage across the capacitor to make sure its the same or close to the value on the schematic.
These are the basics of what to do
I hope this helps
Thank you,
Shuttle83
Posted on Sep 21, 2008
51mp392h/17
If you do not have menu, problem in power supply, supplying the 130v to the high voltage circuit. Check all pico fuses in power supply.
Nov 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
My Magnavox Projection Tv has the 3D appearance for awhile and now it has no picture at all...only sound. what is wrong with it?
Sounds like your convergence IC's need replaced for starters. Not sure if that is causing your no picture though. More than likely you have some resistors out as well as a fuse or 2 in the convergence line. If you have a meter I would start there.
Apr 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
The screen is starting to have red and green blurring
sounds like the coolant if it appears as halos. If it appears like a 3D picture its the convergence ICs.
Jan 30, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Green blured color started at bottom left corner and growing
Based off manufactureing timeline it sounds like you have some capicitors going bad you will need to contact a qualified Service agent for a service call to repair the problem.
Jan 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red and green lines on picture only in the corners of the pic
YIKES, I dont know about Coolant changes but I'll post my general post about the 51MP392H/17
it has links to the SERVICE MANUALS and info to other sites that might help...
GOOD luck
General post....
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
Help! Please
heres the link your needing the DPTV large signal board.
http://servicemanuals.vstore.ca/
Sep 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
No picture
Hello susbudi and Jazz617,
I would suggest do a check on the voltage from the IHVT to the High Voltage multiplier.
This will determine if this is a HV problem or not. If it is not It may be a video delivery problem which would have similar results. In any event both of these tasks I would suggest be preformed by a qualified TV repair technician.
I hope this helps,
Thank You,
Shuttle83
Jul 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51mp392H/17 convergetnt problems
When I turn on my magnavox 51mp392h/17 the sound and picture works but there is a sizzling sound coming from inside of the tv I looked and the sound is coming from what looks like a coil it has 4 lines coming from it 3 of which go to the color projectors and one to what looks like a transformer. Can you help me out?
Jun 06, 2008 | Televison & Video
51mp392h/17 model number magnavox
try resoldering the vertical output IC. That may be the problem bad solder has been known to cause that symptom in the chassis
Mar 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
