Question about Car Audio & Video
I have a Sony CDX-F7550 Radio in my car and want to change the display colour. Is it possible? Vivian
SOURCE: i have a sony cdx-m8800
hi andyrst the wire on the memory lead has no fuse i thought the new ribbon would fix the radio getting fed up with it think i will just give up and buy a new one ?
Posted on Jul 21, 2008
SOURCE: Sony CDX-4000R car audio
One of my sons (40+ yrs) found the answer on the net which was yes it does, and e-mailed me. Incidentally the unit was a Sony CDX-4000R and not a Panasonic etc.
Posted on Oct 06, 2008
SOURCE: How to set time on sony CDX-GT50W
press and hold the volume control dial. when a menu appears press the volume control button until clock adj appears. then press seek to change from hours to minutes. to adjust the hours and minutes just rotate the volume control dial
Posted on Nov 06, 2008
uge44
  • 226 Answers
SOURCE: sony cdx gt100 car radio/cd:
The clock uses a 12-hour digital indication.
1 Press and hold the select button. The setup display appears.
2 Press the select button repeatedly until "CLOCK-ADJ" appears.
3 Press (DSPL). The hour indication flashes.
4 Rotate the volume control dial to set the hour and minute. To move the digital indication, press (DSPL).
5 Press the select button. The setup is complete and the clock starts.
To display the clock, press ( DSPL). Press ( DSPL) again to return to the previous display.
Posted on Nov 20, 2008
ctc1234
  • 26 Answers
SOURCE: unit displays radio tuning but does not lock on
is sounds like the antenna cable is not plugged into the head unit. Pull it out and check.
Posted on Jun 07, 2009
How do I set the time on the Sony CDX-GT300? Car came with the radio but time needs to be set.
http://www.usersmanualguide.com/sony/car_audio/cdx-gt300 and click on the user manual. Or www.docs.sony.com/release/CDXGT300.pdf.
Press and hold the select button until setup display appears. Then press select button until clock-adj appears.press dspl. Use the volume control to adjust hour. Press dspl to change to minute or back to hour. Press select when done.
Jun 21, 2010 | Sony CDX-GT300 CD Player
RDS failure?
some stereos you have to input the name of the station yourself.
May 05, 2010 | Sony CDX-GT310 CD Player
My Sony CDX-C680...
Hello greggerika,
It's possible that the "illumination" wire is not connected or connected improperly. It's also possible that the front panel electrical connections are not making proper contact. Remove the front panel and gently clean the contacts with a pencil eraser.
Also, the CDX-C680 allows you to select either green or amber illumination. One or the other may be defective. Try changing it. Press SHIFT - press "3" (set up) three times - press "5" (right arrow) to change the setting. Also check the setting for "dimmer". ON will result in a dimmed display at all times. AUTO will dim the display whenever the headlights are turned on (if the wiring is connected properly). OFF will result in the brightest display at all times.
Hope this helps.
Jun 13, 2009 | Sony Car Audio & Video
Car stereo illumination colour
there are two versions of that radio. your version does not have a color change option. here is the manual for it. https://esupport.sony.com/US/p/model-home.pl?mdl=CDXGT310&template_id=1®ion_id=1&tab=manuals#
Jun 06, 2017 | Car Audio & Video
Sony CDX-C480 radio
I need the wireing dig for a sony cdx c480
Oct 21, 2007 | Sony CDX-C480 CD Changer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
