Question about Sony Mavica MVC-FD95 Digital Camera
FD95 flash problem!
Just open the box of my FD95. But even in a very dark environment, the flash won't pop up! What's wrong? It's in Auto mode and all setting is from factory. I didn't change anything. Please help! Thanks in advance.
    Master:
  • 551 Answers
The flash doesn't open automatically. There is a button on the side of the camera that says Flash (open).
Posted on Sep 13, 2005
SOURCE:
Is there any Option for solving not working Flask of Nikon L120, Many times I have looking for others opinion. Even reset to Default setting also but not working.
There is a button to release the flash and that makes it pop up. I think in a full Auto (I do not use any camera this way) if it is too dark it should pop the flash up. If you can set the MODE to 'P' you control the flash... not the camera. The Little pop up button is in front on the Left side if you were holding it to take a photo.
Jan 08, 2017 | Nikon Coolpix L120 L-120 26253 Black 21x...
How di I manually pop open the flash
Press the OPEN (flash) button.
This button is on the side of the camera just below the flash.
The flash mode button (lightning icon) is at the lower left on the rear of the camera.
This only changes settings when the flash is up.
This cycles through Auto, red-eye reduction, forced flash and no flash.
The mode shows in the finder or the LCD screen.
AUTO mode does not show.
Oct 20, 2014 | Sony Mavica MVC-FD95 Digital Camera
Nikon D3100 won't flash
If you have set the main dial to the green camera logo, with automatic in bad light, and the flash still does not pop up, you could start worrying. The mail mode dial is very easy to turn, even without knowing. It happens to me more often than I would like. My next camera must have a special button to lock this dial.
When you chaco the manual, you will see there are settings the flash won't pop up and even when it is up it won't flash, because that menu excludes the flash.
Jan 12, 2014 | Nikon D3100 Digital Camera
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
I have a Nikon D40X. The built in flash pops up but the flash does not go off (light up)....not aware of the capability of turning it off manually.
You have 2 options to try before you consider a service tech to look @ the camera.
Prelim : Ensure the batteries are charged & your using standard batteries.
Option 1 : Put the dial in Auto mode and see if that helps with the flash, also ensure you are trying to click the picture in a dim or dark environment, else the Auto flash won't fire if the environment is bright enough
Option 2 : Backup your pictures and reset your camera by using the menu. This should take care of any settings that might have been accidentally turned ON or OFF, then try to get back to the option 1 to see if the flash fires... (you will have to set the date & time post this action)
Mar 30, 2011 | Nikon D40x Digital Camera
Cannon Powershot SD 870
you can change it to no flash by when your taking a picture press the right arrow
Jul 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Flash not automatically opening up.
Check the flash setting in the shooting mode (on Auto). Press the "?" button twice. You should see the flash mode window. Small box on the lower left for flash settings (hi-lighted in yellow, or navigate to it). Press OK to see and change flash settings to your preference.
Apr 18, 2008 | Nikon D40x Digital Camera
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Flash won't open on the d40
The flash on D series doesn't always open by itself or when you push the button, as part of the design. If you are in manual mode the flash should open when you push the button, but when in Auto, if there is enough light present for the flash to stay closed, even if you push the flash button, I don't think it will open.
In Auto mode, try pointing the camera at something dark or holding your hand up in front of it and push the shutter button halfway down to see if the flash opens. If not, you will probably have to take it in to be repaired.
Sep 26, 2007 | Nikon D50 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Sony Mavica MVC-FD95 Digital Camera Logo
57 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
