Question about SanDisk Sansa Clip MP3 Player
Battery not charging
My battery ran low this weekend and when I go to the computer to plug in and charge, it is not being recognized by the computer or charging. In doing this, I have run by battery down and now it will not hold a charge long enough for me to get to my menu.
Any suggestions?
nicki
  • 8,596 Answers
Use the volume + method listed below:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Sep 05, 2008
My coolpad catalyst battery went to 0% now it won't charge or turn on, or be recognized by my laptop computer
lithium polimer batteries take serious damage from over and undercharge, they prefer to stay within 20 to 80% charge. over and under this causes the battery to wear out quicker. with severe damage a possibility if it is allowed to go too low or too high. most devices cut off the battery before its allowed to drop that low and has protection for overcharge. but if you drain it to 0% then let it sit for a while. it may still go below its safe voltage. i would reccomend trying getting a new battery for it. replacing it is fairly easy
Battery Coolpad Catalyst
Sep 18, 2016 | Audio Players & Recorders
ASUS K54C won't power from battery
Take it back to shop if it's only 2 weeks old
May 06, 2017 | ASUS Computers & Internet
I have a Storm 9530. One evening I plugged my phone into my wall charger (not computer) to charge and when I woke up the next morning... low and behold the infamous battery with red line showed on the...
It could be the charger, the phone's power interface, or your battery. When you plug the phone in to charge it, does it recognize the charger and show the lightning bolt symbol for charging?
If you use your computer's USB port to charge it instead of the wall charger, does it act any differently?
Aug 16, 2010 | Cell Phones
Unit shows low battery and immediately goes into hibernation, even though it is plugged into A/C
When plugged in does the battery charge, and do any charging lights on the laptop illuminate. If not then either the charger or charger circuits have failed. The former requires a replacementm charger, I suggest e-bay. The latter requires an expensive motherboard replacement. If all lights are as you expect them to be, and the battery charges, then there could be some obscure setting, or software, that causes this but hardware would be my first suspect.
Please take a moment to rate my solution.
Thanks.
Simon.
Rytech Computer Services Limited
Nov 23, 2009 | Toshiba Satellite P35-S611 Notebook
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
Laptop will not power up with Adapter
It sounds like there is a problem with your motherboard. You would have to take it someplace to run diagnostics on it. It may be time for a new laptop
Apr 14, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My garmin c330 will not charged
Disassemble then disconnect speaker/battery connector from printed circuit board. Individually cut the red, green and black wires from the battery. Tape over the wire ends of the connector and battery wires that were cut. Re-assemble and unit will work when plugged into 12Vdc. If you want to use the battery, it must be charged with an external Li-Ion charger using red + and black - for the charging connections to the battery. With the connector to the pc board disconnected, solder and tape the battery wires to the connector wires where cut. Re-assemble and it will work & charge.
Jan 13, 2008 | GPS
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
SanDisk Sansa Clip MP3 Player Logo
108 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
