Question about Olympus Camedia C-765 Digital Camera
Camera wants you to format when you turn it on.
We have had this camera since December 04 and it always worked fine. We haven't used it much. Lately, when you turn it on, it will automatically go to format instead of letting you take photos. This is even after we have charged the battery. We even bought a new battery. Sometimes, you will be at an event, and taking photos and all the sudden you turn it back on and it wants you to format the card. This would lose all the photos already taken. on a 252 mg card even. Anyone else had this problem. My daughter's wedding is coming up and I need a camera that is reliable.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
On some cards, you will need to clean the contacts of the card to get it to see the card. you can clean with a pencil eraser lightly over the contacts and wipe clean or alcohol cleaner (let air dry for one hour before inserting card back into camera)
Posted on Sep 03, 2008
My Kodak M530 had been working alright since I bought it on December 2010 but suddenly stopped reading the SDHC card about a week ago. The card is fine because I can read the content from my Mac....
Using the internal memory locks some cameras into that mode. To get your card to work again, do this...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, re-insert the card and it should work.
Jul 21, 2011 | Kodak EasyShare M530 Digital Camera
Never used it. Turn on the camera and it says
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
After all this if its not work then the lens guide pin is damaged & replacing the lens is the solution of your problem.
May 19, 2010 | Nikon Coolpix 4600 Digital Camera
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
Panasonic Lumix DMC-TZ5 does not recognise my memory card
1. Go into the menu and find "reset"...follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the instructions.. 3. After downloading any pictures from the card, insert it into the camera and do the "format" thing again. everything should work now. Remember, never use the computer to format or erase your card...always use the camera. Also, when removing the card from the computer, always use "safely remove hardware" icon at the bottom right of your computer screen.
Feb 16, 2010 | Cameras
Needs to be formatted???
DOWNLOAD "IMAGE RESCUE 3".
GOOGLE IMAGE RESCUE 3 ,WHEN IT SAYS,RUN OR SAVE,
SAVE IT IN MY DOCUMENTS, CLICK ON IT TO LOAD PROGRAM ON
COMPUTER.USE CARD-READER, PUT CARD IN WHEN ITS PLUGGED INTO COMPUTER.
RUN IMAGE RESCUE 3 YOU SHOULD SEE WHERE TO SCAN
FOR IMAGES.
ALWAYS FORMAT CARD AFTER IMAGES HAVE BEEN REMOVED
DO THIS IN CAMERA NOT CARD-READER.
BURN IMAGE RESCUE 3 TO DISC YOU ALWAYS HAVE PROGRAM.
Feb 15, 2010 | Nikon COOLPIX L18 Digital Camera
I have a kodak easyshare m1063 THAT WILL NOT TURN ON!!!
This problem is frequently due to corroded battery terminals inside thecamera. Remove the batteries and wipe the terminals with a soft cloth(heavy corrosion may require a fine wire brush, steel wool, orsandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and thenreplace them in the camera. This cures most problems, but if itdoesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Aug 17, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have had my camera for about 4-5 years. It has worked great. lately it has started to act weird. when I turn it on the screen says access and wont let me take a picture. then after a few minutes the...
Go to camera Menu and select Initialize, OK.
Camera will turn on itself, if problem still exist, tap camera gently and turn On again to solve lens access problem.
Memory stick error can be solved by formatting it through Format menu in camera. Use another memory stick in camera to make sure that camera is OK.
Aug 12, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Camera shoes always empty fashcards for FULL
Formatting
This function lets you format a card. Formatting prepares cards to receive
data. Before using non-Olympus cards or cards which have been formatted
on a PC, you must format them with this camera.
All data stored on the card, including protected pictures, is erased
when the card is formatted. When formatting a used card, confirm
there are no pictures that you still want to keep on the card.
Page 173 of your advanced user manual explains how to format the memory card and clear all data from it.
Apr 09, 2009 | Olympus Camedia C-5060 Wide Zoom Digital...
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Memory Card Format Fail
Hi I think its a compatibility issue. Try formatting it using your camera. else format it using Windows.
Sep 14, 2007 | Kodak EasyShare CX7430 & EasyShare Printer...
Olympus Camedia C-765 Digital Camera Logo
32 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
