I cannot restart my iphone 3G even I reset it. the white apple logo appear, and a 'loading cycle' appear... but then it switch off and repeat the same loop again and again...
could you help me out, please...!
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time.
Hold them both until you see the screen go black. In some cases, you may need to keep holding them even after the red power off slider appears. If it does, just keep holding it.
Wait until the white Apple logo appears.
When this happens, you can let go - the iPhone is rebooting.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it. Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears. If iPhone won't turn on, or the display freezes or doesn't respond
Press and hold the Home button for at least six seconds, until the application you were using quits.
If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets: Try This: 1. Remove Sim Card 2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears 3. Replace Sim Card 4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this: 1.) Shut down the iPhone 3G. 2.) Start up iTunes 3.) Hold down HOME button on the iPhone 3G 4.) While keeping the HOME button depressed, plug in the Sync cable 5.) A message will pop up to ask if you want to reset. 6.) Just click YES and the reset process should start.
Try resetting the iPhone by pressing the Sleep/Wake Button and the Home Button both simultaneously after which the phone restarts slowly with the appearance of apple logo on the screen. Normally, reset is the solution for such strange problems.
Try each of the following resets: Download the latest iTunes to your computer and reset the iPhone. Then re-sync it. Reset To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears. If iPhone won't turn on, or the display freezes or doesn't respond
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Try these resets: Download the latest iTunes to your computer and reset the iPhone. Then re-sync it. Reset
