Question about Quantum Fireball Lct20 (QML30000LD-A) 30 GB Hard Drive
Quantum fireball LCT 15
I need to create backup harddrive for old IBM cpu. It has a quantum fireball
#QML15000LC-A hardrive (15GB ) that has been set up as 10.1 GB
( IBM P/N 19K1552 ). I have a spare 15000LC-A drive , but can't find a way to convert it to the 10.1GB setup. Have tried ghosting the drive and fdisk.
Is there anyway to reformat drive to duplicate 19K1552 setup?
    Master:
  • 397 Answers
Quite honestly the best harddrive cloning/imaging software is EZgig.
I use it all the times on older machines and branded machines where they have a hidden recovery partition. If you run EZgig in advanced mode it will duplicate the original harddrive for you right down to setting up the partitions.
The best way to do it in your situation would be to load EZgig on to an XP machine and slave the original and then backup harddrives to the XP machine.
Here is a link to the Acronis True Image download (same software as EZgig) this is a fifteen day free trial.
http://www.acronis.com/homecomputing/download/trueimage/
Posted on Sep 02, 2008
    Genius:
  • 1,142 Answers
Please refer to the following link
http://www.pcguide.com/proc/setup/hdd-c.html
I need firmware for quantum fireball lct 15. thenk you
I have a firmware for fireball lct15 a01.0f00. If you need it give me your e-mail adress and i'll send it to you.
Mar 24, 2011 | Quantum Fireball Lct15 7.5 GB ATA-66 Hard...
Need jumper setting for quantum hdd 3.5 series fireball lct ,LB10A011 10.1gb to set up as a slave hdd ,thanks
Try this if not then get back to me and i will see if i have another diagram. I had to dig for this info too old haha. i still work with this stuff
Feb 27, 2011 | Quantum (LB10A011) Hard Drive
Please email me at duokeystrings@yahoo.ca if you can answer the following: 1.How do I connect internal quantum fireball lct 20 3.5" 40.0 GB externally? 2. Is there a patch cord that will connect from...
this link will show you the only device you will ever need. you can conect any size hard driv or any type hadrdrive to your PC. i use this constantly and its wonderful. also it is on sale for 19 bucks so you would get it 10 bucks cheaper then i paid for mine.
Vantec CB-Isatau2
VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002&cm_re=vantec_sata-_-12-232-002-_-Product
one other thing, Newegg is a trusted site. i have dealt with them for years. if you get a bad part they will stand behind it.
Feb 05, 2011 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
I have a hdd quantum fireball lct 10 3.5" series with the serial number 973006916882 papxx power req 5/12v 600/900 ma. My question is about the capacity of this hdd since it is not written as I want to...
my hdd was install in IBM pc. Aftr that i am install my hdd in my assemble machine. My hdd is good condition.In BIOS HDD property is show perfect but when i want to format my HDD maybe fdisk or winXP CD my HDD is not work properly from this time. Please help me..........
May 20, 2010 | Computers & Internet
Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Jumper go`s in what line.if power out let it on my right handside
moz-screenshot.jpgHere is a picture I found that shows the jumper settings for:
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
http://www.tacktech.com/images/articles/379/mxo_ata_jumpers_2.png
Apr 26, 2009 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantium 10.2 gb fireball CX10A011 specs. ie sectors, mode, etc.
The specifications to enter the information manually, are on top of the harddrive. Kind of hard to discern, huh? That's because harddrive sizes from 6.4GB through 20.4GB are listed on top.
C/H/S = Cylinders/Heads/Sectors
The Quantum Fireball CX10A011 hardrive is a 10.2GB harddrive.
You will see -> C/H/S....10.2 - 16383/16/63 on top.
That is ,
16,383 Cylinders
16 Heads
63 Sectors
As for the 40GB model, it should be similar. If not, come back and post.
Jan 22, 2008 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Having trouble using it as a solo harddrive in newer computer
When Windows (XP?) was installed in the Quantum Fireball LCT1520 of the old Compaq Presario, the OS was married to the hardware specifically the motherboard/chipset. When it was removed and transplanted to the newer PC, the OS would be looking for the old hardware settings/configuration and since the new PC has a different motherboard and therefore cannot find the old hardware, it would loop/reboot continuously and/or BSODs.
One method of getting the old HD to work in the new PC is to do a clean/new install of the OS.
If for some reason you prefer to use the old OS in the old HD with its settings/configuration, you can try to do a repair/re-install. The procedure is similar to installing a clean/new OS except that you should opt for the 2nd repair choice (not the R or first repair option). This should retain most if not all of your old applications/settings while installing new Windows files.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Dec 03, 2007 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum Fireball Lct20 (QML30000LD-A) 30 GB Hard Drive Logo
339 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
