Hello friend,, you can find the canon d660 service manual in the below link:
http://goo.gl/zMSkC8
Thanks
SOURCE: Canon imageCLASS D660
you can find the same on Canons Website. Don't go for the exact model no. D600 series uses the same driver.
SOURCE: canon d660 imageclass copier
Hello himsmyboy!
Sikna says
The ADF separation pad is the cause. To remove it lift the cover fully up then use a knife to get under the black tape tab at the top right of the large white foam pad. Pull the tape and the white foam pad loose but not completely - leave the bottom attached. Now you can see the ADF separation pad from below. Use a small screwdriver or spring hook to remove the spring and you will be able to wiggle the ADF separation pad out. First take a good look at how it fits in so you can put it back! The problem is caused by the small black foam pad under the white rubbery tape on the ADF pad assembly. I carefully removed the tape from the back edge to expose the compressed black foam pad. I then cut a matching size of 1/16" foam I had in my shop which was actually HP 98A doctor blade seal foam and just stuck it on top of the old compressed foam. (other similar foam should also work) Then I replaced the white rubbery tape and rubbed the edge down well. I then reinstalled the restored ADF pad and the spring which holds it. Last I just pressed the large white foam pad back into position - being sure to pull it with a slight tension as I pressed into place. This fixed the ADF feed and it worked like new again...
Sikna out...
SOURCE: Need user manual and/or service manual for Canon imageCLASS C2100
here you go...this printer model is known as cp660 on other regions (based on their Web site).
http://printer1.blogspot.com/2008/03/canon-cp660-service-manual.html
hope this helps.
SOURCE: How to replaced fuser on the Canon ImageClass 780
the steps are posted on the reference guide found in the link below from Canon
http://gdlp01.c-wss.com/gds/0300000515/imageCLASS_D780_D760_D761_Reference_Guide_EN.pdf
SOURCE: CANON IMAGECLASS MF6550 service manual
http://www.retrevo.com/support/Canon-MF6550-Multifunction-Printers-manual/id/1071dj288/t/2/
you can download the manual in this site
