Question about Sony Mavica MVC-FD95 Digital Camera
Need Help FD95 Memory Stick
Purchased a brand new FD95 and a memory stick FD2MA with 64mb just last night. I've follow the instruction correctly to install the memory stick. But when I tried to take photo, LCD display says "Format Error" at the center of the LCD display and C:13:01 blinking. Help , I don't know what to do. Do I need a drive to format the memory stick????
  • 69 Answers
Not all fd 95 are memory stick compatible !
Posted on Sep 21, 2007
SOURCE:
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
I need the memory stick number to my dcr-trv18 what memory stick do i need
Your camcorder uses the original Sony memory sticks in the following capacities:
4Mb, 8Mb, 16Mb, 32Mb, 64Mb and 128Mb. All but the 128Mb have been discontinued. You can look online for the 128Mb memory stick from many vendors. You may find the other ones from E-bay.
Apr 14, 2011 | Sony Handycam DCR-TRV18 Mini DV Digital...
What memory card do i need for my sj30 and where can i purchase it?
You need a Sony Memory Stick
Here's one on Amazon: http://www.amazon.com/Sony-MSH-M128A-Memory-Retail-Package/dp/B0000D8HLL/ref=pd_sim_e_1
Mar 05, 2011 | Sony CLIE PEG-SJ30 Handheld
What is meant by a memory failure Replace dimm 0
There is a memory stick in a socket on the formatter board in the right side of the machine. If you pull the right rear cover to the rear it will come off revealing a metal cover you open by the tab. Once open it shows the formatter board. Inside is a laptop sized memory stick,or DIMM. With power off you spread the tabs to release it then pull the memory out, same as in a laptop. You likely have 96mb RAM - most come with a 64mb memory on the formatter (non removable) and a 32mb option. On the P3005N and P3005DN the memory is required to make the embedded (builtin) network card function, otherwise you can run it fine without the bad DIMM if you use USB. If you want to replace you need a 200 pin DDR2 DIMM in either 32mb, 64mb, 128mb or 256mb value. Last I bought was on ebay for $20 for a 128mb brand new. HP wants like $220 for the same.
May 19, 2010 | HP LaserJet P3005n Printer
Memory stick error when camera is turned on
Hi
How about download the user manual from this link
http://www.docs.sony.com/release/DSCV1.pdf
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Memory stick for Sony Mavica FD92
Most older digital cameras do not work when you try to use a memory stick adapter and the newer, smaller size memory sticks. Because this memory format is so old that it is no longer sold in retail stores, your best option is to buy a memory stick online. You can find these memory sticks on eBay.
To find more eBay auctions for these memory sticks, go to the Memory Cards category on eBay. Then, on the left side select Format = Memory Stick, and Storage Capacity = 64MB and under.
In the resulting search, only look at the auctions that are actually for 64MB and under Memory Sticks - you will find a lot of mis-classified memory in the search results - items that are the wrong format (not memory sticks) or too large to work in your camera.
Dec 13, 2008 | Sony Mavica MVC-FD92 Digital Camera
Problem accessing memory stick
I had the same problem. I bought a 2 gig memory pro-duo with the adapter and it gave me that error even though it fit just fine. I then tried a 512 memory stick and a 1 gig memory stick and neither one worked it gave me the C:13:01 error code. So I found out the hard way that the camera will not read it. The Sony DSC-S85 will not take memory above a 128. Try the Lexar 64MB memory stick. I just bought 4 and they work perfectly fine.
Nov 02, 2007 | Sony Cyber-Shot DSC-S85 Digital Camera
FD95/memory-what do I need?
You need the MSAC-FD2M Floppy Disk Adapter. It's probably going to be hard to find these days.
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
Memory Stick On FD91
No, the camera does not have drivers for the memory stick in its firmware, only the announced FD95 has this feature.
Sep 12, 2005 | Sony Mavica MVC-FD91 Digital Camera
Sony Mavica MVC-FD95 Digital Camera Logo
159 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
