Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi 62" dlp wd-62525
I just bought this tv from a friend the lamp light was blinking, replaced the lamp now the timer light blinks then goes off then if i press the power button the status light starts blinking red, 4 blinks. any suggestions?
  • BitterTVMan May 11, 2010
    Please check the length of pause between each blink. There are 2 numbers being passed to you. The first set of blinks has short pauses; then there is a long pause; then there is a second series of numbers. So, your 4 blinks could be a: 1-3 error 2-2 error 4-4 error 3-1 error We need to know which one it is.
  • 64 Answers
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Posted on Aug 01, 2009
My Mitsubishi tv model wd-62525 not on the light of timer is linking
If one light is blinking (lamp light?) remove and inspect lamp to make sure it is in correctly and not shattered. If the set has a recessed reset button on front (if set is unplugged and plugged back it should blink green for about 70 seconds and go out) you may have a issue there.
The model indicated here has a host of problems.
May 20, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a WD-62525 TV and I was getting a message
The lamp cover isnt secured properly that what causes the staus light to blink yellow.
Dec 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have WD 62525 timer blinks very rapidl but wont turn on or off
HOwdy;
Try unplugging TV from a/c for 2- 3 minutes. Plug back in, turn TV on. If red light turns on (Lamp may light and go out) suspect bad lamp part # 915P020010.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
5 year old mitsubishi wd-62525 with blinking timer light. This site says there aren't replacement boards available for it any more. Also to send it to a technician for repair. One suggestion was that it...
The WS62525 doesnt have an inverter board. The blinking led is usually caused by failed capacitors on the DM board. You can get the V26 Chassis dlp DM repair kit at the following link which contains the capacitors and the CD with detailed instructions. www.tvrepairworld.com
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
458 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
