Question about Kenmore 22422 Top Load Washer
Kenmore washing machine
I have an F3 error flashing. What do I do?
Thank you
  • Kenmore Master
  • 19,396 Answers
F3 on Kenmore/Wirpool a faulty lid switch.
Try unplugging machine for one hour, and see if this clear the error.
If you still get the error message you will need to replace the lid switch, see manual here.
Posted on Sep 08, 2008
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
It keeps saying f3 when i push start
If I am correct the F3 error has to do w/ the lid switch of the machine. While I'm not totally familiar with this model, I would first make sure the lid switch if it is a prong push type is not broken off. If it is magnetic I would check it for operation or for loose wires.
May 03, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
Kenmore 22422 Top Load Washer Logo
188 people viewed this question
Sal De
fordexpert
Robert Rankin
