Question about Sony Mavica MVC-FD95 Digital Camera
Mavica FD95 Flash Quit Working???
Hello, My flash recently quit working on my Mavica FD95. For awhile, I was using the separate Sony flash unit (but I dropped it and it has quit working too). I am leaving for vacation on 8/16 and won't have time to arrange for it to be repaired between now and then. Any ideas or suggestions as to things I might do to get the flash working myself? The flash pops up, and the flash icons show on the digital display, but the flash does not flash. Thanks in advance! Amy Strycula
    Master:
  • 551 Answers
My flash went out twice on my FD-95. The first time it was fixed under warranty and it was the bulb. This time I haven't fixed since I have my 707 now. It still works with the external flash like yours did before you dropped it. If possible I would try and buy another external flash since your time is short. When I had my camera fixed under warranty it was just about to run out and they, the camera shop, told me I should get it fixed now instead of out of warranty because the cost could be hundreds just in labor alone. Good luck.
Posted on Sep 13, 2005
How di I manually pop open the flash
Press the OPEN (flash) button.
This button is on the side of the camera just below the flash.
The flash mode button (lightning icon) is at the lower left on the rear of the camera.
This only changes settings when the flash is up.
This cycles through Auto, red-eye reduction, forced flash and no flash.
The mode shows in the finder or the LCD screen.
AUTO mode does not show.
Oct 20, 2014 | Sony Mavica MVC-FD95 Digital Camera
Sony Mavica FD95 Camera
This is a common problem with the Mavica FD95. There is a little switch in the drive slot to sense the write protect tab on the disk.
If you hold open the drive door without a disk in, you should see this switch where the write protect tab goes. Try operating the switch with a matchstick a few dozen times to attemp to clean the contacts. If that doesn't work then Very carefully let a drop of switch cleaner run into the switch and try operating it a few times then let it dry. Failing that you might want to open the camera to get to the terminals on the switch and test it with a multimeter.
If the switch is faulty and a replacement is not availble then you could just short(or disconnect) it to fool the drive into thinking any disk is writable.
Good luck
Oct 19, 2007 | Sony Mavica MVC-FD95 Digital Camera
Flash quit working
Please replace the give below part.
A-1444-049-A ST BLOCK ASSY
And your camera work fine again.
Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Storage/memory used SD or usb flash disk
Try setting your picture size to a smaller size. If your pictures are used mostly for being viewed on a computer, or for smaller print sizes like 3x5 or 4x6, you should not lose any quality. The smaller file size does not take as long to write to the disk.
Feb 28, 2008 | Sony Mavica MVC-FD95 Digital Camera
Flash now working
did you by chance cover the flash at any time before it quit working? if so and you covered it closely then you burned out the elament. i did the same thing to my old mavica. it would flash when i didn't want it to so i covered it just to burn it out.
Aug 27, 2007 | Sony Mavica MVC-CD250 Digital Camera
FD95/memory-what do I need?
You need the MSAC-FD2M Floppy Disk Adapter. It's probably going to be hard to find these days.
Sep 13, 2005 | Sony Mavica MVC-FD95 Digital Camera
Mavica FD95 and Sports Photography.
Basically you bought the wrong camera for your needs. The 95 can not do well under the conditions you describe. The ISO is fixed and to low for the amount of light you have available. The viewfinder begins to darken after the lens is wide open and the shutter speed is increased further. There are three possible cures. More light, not possible in your situation, faster lens or higher ISO, again not possible with your camera. Maybe you could convince them to play in the dayight. :)
FD95 flash problem!
The flash doesn't open automatically. There is a button on the side of the camera that says Flash (open).
Mavica FD95 Error Msg C:13:01
A Cxxxx error normally can be fixed by the user. I suggest you remove the battery pack AND the button cell (I suppose the FD95 has one) and leave it without both for at least half an hour. I would think that after that, it should be ok except that you'll have to set the clock and some other preferences again. Hope this helps.
FD95 underwater housing?
2 ziplock bags and alot of duct tape (serious) itll be good down to about 10-20meters. It's limited use, but it works.
Sony Mavica MVC-FD95 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
