Question about Brother 1034D Mechanical Sewing Machine
Brother 634D Tension Problems
3 of the 4 tension knobs are loose and go all the way around. No adjustment seems to help. I don't know if someone took apart and did not put back correctly, seller said that it worked. Is there an easy fix or am I going to have to spend $100 to get repaired at shop?
textile
  • 10 Answers
SOURCE: how to change tension from 120V to 220V
If you are sending a sewing machine which runs on 120volts to a region that has a 240volt power supply you will need to get a
power step down converter that will fit into the socket of the 220volt supply ,and will have a socket that will hold the plug of the 120volt supply going to your machine.
the converter must reduce the 240v down to 110v .
Posted on Aug 01, 2008
redbeard00
  • 957 Answers
SOURCE: Thread tension for Brother XL 2230.
If you have pattern dials set correctly then I might guess that one or more sets may have been missed when the thread was being set up in the machine. most of these models show either arrows or numbers for each or way the thread needs to be routed.
Posted on Apr 26, 2009
SOURCE: my thread tension knob fell out of my machine and
My machine was doing the same thing its a sunstar 340-bl.Any way it was caused by aplying to much tension.To put back in remove barrel buy undoing grub srew,once removed, barrel will have one or two screws these are what hold tension shaft under tension in place.I can not advise on how much tension as i have different machine and once you destroy your spring thats it,you need a new one.To much tension causes it to untwist.
Posted on Jun 13, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
  • 1116 Answers
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Posted on Mar 11, 2010
Tension to loose and missing stitches
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
use a scrap piece of fabric to sew on as you adjust the tension
when the tension is to loose adjust one number higher till stitch
looks good
here's 2 links for a manual one is a hardcopy & the other is a
pdf downloadable--one is a different price from the other
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d.aspx
http://www.sewingpartsonline.com/instruction-manual-janome-mylock-634d-download.aspx
Sep 08, 2012 | Janome MyLock 634D Mechanical Sewing...
I have a VX1250. I don't know how to regulate the tension.
There is two places to adjust thread tension: the top tension device controls the top thread tension and is usually a dial or knob with numbers on the front of the machine.
Then there is some form of tension device on the bobbin; in your case I believe the Brother has a removable bobbin case with a tension spring which holds the bobbin thread firmly: the tension spring can be adjusted with a screwdriver but once set, you shouldn't need to adjust this much, just alter the top tension slightly for different weights of fabric. So start by setting top tension dial to 4-5 and test stitch a seam. Use different coloured but the same type of thread top and bottom and take a look at the seam. You want to see a balanced even seam.
Here is a link to a great info site for this:
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If the bobbin thread is too loose, then you probably will need to finess the tension spring on the bobbin case and adjust this slightly. The best way to set the tension on the bobbin case is as follows. Load the bobbin into the bobbin case and pull the thread tail into the tension spring, then suspend the bobbin by holding the thread tail up in the air (the dangle test). You want it to be just tight enough to hold its own weight, but still able to release thread when you pull gently downwards on the bobbin case. If it isn't doing this then take your little screw driver and adjust the screw on the leaf tension spring by ONE QUARTER TURN ONLY. Lefty looser, Righter Tighter. Then test again, and adjust again until its right.
Now test stitch again and finess your top tension to get the seam even. Remember to change the needle for each new sewing project too; this will impact tension also.
Jan 04, 2012 | Brother Sewing Machines
I have axr65.have lost my manual,having tension problems.stitches loose and loopy.need help immediately.
Let me give you instructions for adjusting the tension on anysewing machine. Be sure to have a scrap piece of the fabric you are using andthread the top of the machine with a different color of thread than thebobbin-it'll make it easier to see what's going on. Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing. Keep sewing a few inches at a time until you have the resultsyou want. Now you're tension is where you need it!
Jun 15, 2011 | Brother XR-65t Mechanical Sewing Machine
The stitch on the bottom of the material is very loose and is bunching and looks terrible, the top thread keeps skipping and breaking, Ive fiddled with the tension and still having problems
Let me give you a general lesson on adjusting tension that will work for any machine. I suggest you thread the top of the machine with a different color thread than the bottom so that it's easier to see what adjustments you need to make.
May 22, 2011 | Brother XL-5130 Mechanical Sewing Machine
Bottom tension too loose.
Is it looping on the bottom of the fabric? If so this is a top tension issue, you need to check some things,
-make sure you thread the machine with the pressure foot up ( this allows the tension discs to open up so you can pull the fabric away from the machine with the foot up and allows the thread to get to bottom of the tension discs)
-make sure your tension settings are set to the medium setting. (Usually 4 or 5)
If this still does not help, then turn the top tension knob up (from 5 to 6,7,8,9....)
-If that still doesn't do it, your probably need the tensions reset. Let me know if you need more help.
-Chris
Jun 05, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
Lower thread tension is too loose but no adjustment seems to work
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 28, 2008 | Brother LS-2125 Mechanical Sewing Machine
Hello I have misplace the manual for my Janome 234D. I bought it a few moths ago and i set all the tension right and had it going good. But my young grand daughter got to it while i was out and turned all...
Tensions all should be set at "3" for general sewing if there is no other damage or lint trapped in the tension discs.
Try "flossing" each tensioner with a piece of cloth to remove lint.
If you are still uncertain, try 4 different colours and with all set at 3 to begin, adjust to suit what you see to be loose or tight (small adjustments each time)
If the little one has removed the knobs (they just pull off towards you) and turned the white adjustment wheel beneath, you need to set until happy as above, then put the outer knob back with number 3 in the 12 o'clock position.
Best of... www.bargainbox.com.au
Nov 26, 2008 | Sewing Machines
I am having trouble with my tension on my Brother Pacesetter PC-4000. The top tension is fine, however, the bottom tension is loose where it can be pulled out. Typically, I know that you adjust the top...
Go to this website page and it will help you. http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faqh/000000/000000/000044/faqh000044_001.html?reg=eu&c=gb&lang=en&prod=hf_inov700eeuk&Cat=52
Aug 18, 2008 | Brother PC-6000 Pacesetter
Mylock 134d janome
make sure the needle is pushed in properly.
Jun 24, 2008 | Janome MyLock 634D Mechanical Sewing...
Ls1217 Brother
It sounds like you may have uneven tension between the bobbin thread and the upper thread. You can adjust the tension via a screw on the bobbin case. Turn it clockwise to tighten the bobbin thread tension and counter clockwise to reduce it. It's also worth remembering to check the tension on the presser foot for the material you are using. Check also that the shuttle race is clear of lint etc. Hope this helps
Jul 02, 2007 | Brother LS-1217 Mechanical Sewing Machine
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
133 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
