Question about Microwave Ovens
Panasonic S943 microwave activates when door is opened. Light, Fan, and Turntable all come on when door is opened. Still cooks normally when door is closed.
I had exactly the same problem with Panasonic NN-S962. I found very useful technical guide on the following website: http://www.eletrodomesticosforum.com/es/cursos/horno_microondas/Inverter.pdf
In the troubleshooting table on pages 31-32 it correctly states that this problem is caused by shorted primary switch. The technical guide has diagrams and photos helping with locating primary switch. I ordered a replacement switch from Sears PartsDirect (part no.46-692286-3). However, it is a common Omron switch V-15G-3C25 or its replacement with 16A analog sold by Sears PartsDirect that may be purchased cheaper elsewhere. After I replaced the switch my microwave started working normally. It was the easiest fix ever. Took me more time to research the problem and find the right part than actually fix it. That's why I decided to post this solution to save time for those who experience similar problems (looks like a fairly common problem for Panasonic microwave ovens).
Posted on Jan 29, 2011
  • dmarie Nov 30, 2011
    also finding same to be true--with Sharp Carousel
  • Dizpo Zabl
    Dizpo Zabl Apr 13, 2014
    Found local substitute: Honeywell High-Force Pin Plunger 15A V71C17D8 (V33001D8) - $4.10
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Maytag microwave "turntable", light and cooling fan stay on after cooking complete.
you can leave the door ajar for a change - it also eliminates the odor inside the microwave
Oct 26, 2012 | Maytag JMC9158AA Microwave Oven
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Loud pop and now doesn't work
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can order Panasonic parts from Tritronics but if you only need a switch, you can order one from us for $5 postpaid.
Oct 09, 2008 | Panasonic NN-T694SF Microwave Oven
Microwave turns on when door is open slightly
It's due to the timing of the opening of the door switches.
It's normal in most cases, and it is not cooking.
Normally it's just the light, fan, and/or turntable that come on.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 28, 2008 | Kenmore 62109 Microwave Oven
Turntable goes around when the door is open and the microwave is off.
Do not run the microwave with the door open. You will be cooked. Sooner or later, if there are enough microwave ovens, (and there are), everything that can go wrong with them will, eventually. There are several interlocking safety systems built into every microwave so that they won't work with the door open. Yours may have failed. I've never come across one, but that doesn't mean it can't happen.
It may only have a fault making the fan and turntable operate, which can sound like it's working with the door open. Either way, get it checked or get a new one.
This assumes that the microwave isn't actually supposed to do what it is doing under normal conditions or current programming. Refer to manual/instructions if unsure.:::Spiceweasel.au
Apr 03, 2008 | Kenmore 80809 Microwave Oven
Microwave on its way out?
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
Feb 24, 2008 | Panasonic NN-S961 Microwave Oven
Microwave Oven Problem
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It's probably not actually heating with the door open, but better safe than sorry! If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 10, 2007 | GE JEM25 Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
234 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
