Question about HP Photosmart C7280 Laser Printer
Failure to Allign
When trying to allign the black bar at top of page will smear on the left side. When trying to print a regular page of black & color the first couple of pages will print OK and then the black starts to get lighter and the print becomes to light to read.
The printer was purchased in April of this year and is under extended contract. But if there is a quick fix I would like to get on with the printing.
  • HP Master
  • 4,338 Answers
This could be the Fuser Assembly. The Fuser is the unit that heats up and makes the toner ahere to the paper. The fact that it is smearing, means that the Fuser is not heating correctly. I would call for service on it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 03, 2008
Sir I have canon selphy cp780printer While I am printing a page I am blank paper each and ever try and also I have Changed my catredge
After changing the cartridge you need to clean and allign. Go to tools menu on printer and clean and then allign. try
Aug 18, 2013 | Office Equipment & Supplies
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Hi. I cant get my printer to allign. I've just replaced the black ink cartridge and when i put the allignment page inside the scanner it wont scan
Did you try to align the unit manually or with the computer?
Alignment page does not print
1 Make sure you remove the sticker and transparent tape from both print
cartridges.
2 Make sure the color print cartridge is secure in the left carrier and the black
print cartridge is secure in the right carrier.
3 Make sure you loaded the paper correctly and did not force the paper into
the printer.
Aligning your print cartridges without a computer
Make sure you follow the steps on the Setup sheet to complete hardware
installation. Continue with the following steps to optimize print quality.
1 Make sure you have loaded paper into the paper support, and then press
and hold Scan for three seconds. For help, see "Using the control panel"
on page 4.
An alignment page prints.
2 Place the printed alignment page onto the scanner glass.
3 Press Scan. For help, see "Using the control panel" on page 4.
Once scanning is complete, your print cartridges are aligned for optimal
print quality.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Lexmark X2550 All-In-One Printer
Black catridge printing is not working
Hi Aravind,
Are you using a refill cartridge? It would be best to allign after installing the cartridges?
Since most cartridges today have electronic contacts on them, if you dirtied them before installing the cartridge, it is possible that this could affect the performance, you might want to take the cartridge out and clean the contacts with rubbing alcohol.
Also, the alignment of the print heads may need to be adjusted, my hp requires this to make sure the color and black line up properly, otherwise you get a blurry image.
Furthermore, if the problem is with the color cartridge and you are trying to print a page of black letters and the printer is set to use colors, it may try to print the black using all of the colors instead of using the black cartridge. So you may need to clean the color cartridge as well. Try looking at the printing properties and making sure black is selected when printing something that is only text and see if it does it correctly then.
Good Luck!
Jazerblue
Aug 24, 2009 | Epson Office Equipment & Supplies
Printer will not Print Black Ink copies
try to clean and allign the catridges from the front panel menu of the printer..
regards,  raj_p5983
Jan 11, 2009 | HP Photosmart C5280 Printer
After putting a new black and white ink cartridge into the printer, it keeps printing the alighnment sheet everytime I turn the printer on. Ugh! What a waste of ink.
actually it is given in that allign page printout that how to stop this.
but listen the procedure.
after the allignment page is printed just place that allignment page in the scanner .the readable side of the page on the glass.then press OK/ENTER what button present in your printer.
the allignment will start.the printer will read the page.and allignment will get completed.then after u ON the printer it will not give you such problem till u replace the cartridges.
Nov 14, 2008 | HP Office Equipment & Supplies
Color now is pink, does this mean I should repace cartridge @HP D4160
yeah replace the color cartridge, first allign the cartridge if problem presists then change it
Oct 31, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Feb 20, 2008 | HP PSC 950 All-In-One InkJet Printer
HP Photosmart C7280 Laser Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
