Question about Dishwashers
My matsui dishwasher dosnt go through the wash settings any more the dial dosent rotate as normal
  • 1 more comment
  • Anonymous Dec 18, 2008
    Hi, mine is a Matsui MS160SL, and is not heating up the water. IIs this what yours is doing? I think that may be why its not completing the cycle. I have today renewed the heat element, but still no joy.
  • Anonymous Jan 21, 2009
    I have a Matsui dishwasher and I have the same problem in that the water isn't heating up and the dial doesn't seem to be completing the cycle.
  • Roy Bayliss May 11, 2010
    I've got the same problem and no solution yet. I've replaced the heating element - no good. Then the thermostats - no good. Think I might scrap it and get a new one. (It's only 18 months old.....) My advice is - beware before starting to replace parts on these machines, if you're not careful you'll end up replacing the whole machine and it'll cost more than a new one. RB
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: DISHWASHER
this is a sign of a defective timer mechanism. replacing the timer will fix this issue. Replace the timer/control model asap.
Posted on Jun 11, 2009
SOURCE: my matsui mf2w/a dishwasher sticks
check the safety thermostat which is located at the bottom of the dishwasher. you have to remove the bottom plate,and then you will find easily the thermostat-KSD201/PF 90. you have to reset this probably.there is a red wax dot in the middle this thermostat, so remove it and use a needle to press a very small button inside. the heating element is working well probably.you can measure resistance on it to be sure.
Posted on Feb 02, 2010
Macmarkus
  • 2605 Answers
SOURCE: I set rotary dial for Normal Wash which it does
Hello, welcome to FixYa.
I will start by saying your post indicates it is a Kenmore portable dishwasher, however based on the info you posted and my experience, I don't think there really is a problem...if I understand your post.
Just to clarify, "rotary dial keeps turning automatically thru t Water Miser, Rinse Hold, Drying, Plate Warmer until reaches Off " unless what you are saying is the unit doesn't turn off even when reaching "off'.
Let me know if that is indeed the case, otherwise it is working as it should. Whether you select Pots & Pans, Heavy Wash, or Normal Wash or even Water Miser it should run until it reaches "off" on your model of dishwasher.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Jun 01, 2011
Turn on dishwasher you can hear it fill then it turns off
Some dishwashers have a delay start, (frigidaire has this). check the dial settings to
see if your unit has to have the dial rotated past the "delay start hours" setting. Hope this helps.
May 27, 2011 | Dishwashers
AFTER SETING THE WASHING MODE AND LOCKING LEVER I CANNOT ROTATE THE ON OFF DIAL.
Is it an old kitchen-aid? They were actually made by Hobart and you had to select a cycle and then close the door. It was normal only for that model.
Cheers!
Jan 22, 2010 | Dishwashers
My bosch dishwasher dosnt get hot the element is ok
Does it have a thermostat that you can set the temperature seperately? If so, i would check the over temp thermostat firstly.(possibly it has a push button reset.) Normally found near the element,If good, check the temperature thermostat.Unfortunately, it requires using a tester to check for continuety.and resistence. Normally, that should solve the problem.(Im taking it that the element is ok as you have stated).
Nov 12, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Matsui mf160 starts its wash cycle and timer stops
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
Jul 06, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
My matsui mf2w/a dishwasher sticks during cycle. normally about 10 minutes into the wash. i can move it on manually but the wash is poor. the water does not appear to be heating
Dec 02, 2008 | Dishwashers
DISHWASHER
Nov 03, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
The washer does all the normal processing but the dial progresses but the washer just washes, washes, washes. It is almost 40 years old (Maytag). When rotating the knob to the wash setting, the internal...
hi thanks for the question i would replace the timer that washer you have is a very good washer a lot better than whats out there keep repairing very good washer thanks the appliance doc
Sep 27, 2008 | Washing Machines
Hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Dec 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
499 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
