Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet metallic rubbing sound
When I turn the drum manually in either direction, there is a metallic rubbing sound. There is no noticeable friction or resistance. The last load may have included stuff like metal hair clips from my daughter's pockets. I suspect one of these to have gotten loose from the pocket and and then gotten in between the drum and the drum housing, whatever it's called. I have tried using a flashlight to look thru the holes but I can't see any foreign objects. Is there a way to "get inside" the drum housing to remove whatever is in there or should I just call the repair guy?
    Genius:
  • 1,028 Answers
If you've already ck inside front of door boot call repair acess from front can be tricky to almost impossible without removing complete door boot or worse
Posted on Sep 03, 2008
I have a Duet Whirlpool Front-Loading Washer and the last couple of days I've noticed there has been water in the drum. I ran it through just the drain/spin cycle it appears to remove the water only to...
Sounds like you have a seal issue. Try and shut the water from the back connection off after you do a load. I believe that it sounds like you have a leak from the gasket and it is letting water in when you don't want it there. If the water isnt there then we have narrowed the issue. Please let me know what happens. Hope it helps!
Dec 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer make a loud banging sound during spin - louder when it goes into super spin
It sounds like the spider or support arms that hold the wash drum have failed and the drum is hitting the wash tub when it is spinning. Try spinning the inner drum by hand and listen for any thumping sounds as it turns. Also examine how it turns, if you notice that is wobbles as it turns, it also means that the supports are failing.
It can be fixed but it might be expensive. Get a few estimates before deciding to repair or replace. Hope this helps you.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
Whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet dryer drum rubbing
There is a felt seal on the drum that might be wore and will need to be replaced.(Note if not replaced it will ware your drum and ruin it.
It is something you will probably want a repair man to check out for you.
Oct 21, 2009 | Whirlpool GEW9250 Electric Dryer
Duet Washing machine... Sounds like metal loose
you will have to lvel the machine,cause when its not balanced it will do that,so under the machine there are 4 plastic that hold machine u can turn each one which way u need and make sure its leveled
Sep 13, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GHW9100 Drum Knocking/Plastic Tub Shredding
This is joyce
The bearings is gone in the drum, causing the drum to rub and run the wrong way one the pully, yes it is very exspensive, I have the newer model.
let me know if I can help
thanks
joyce
Feb 13, 2009 | Washing Machines
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Noisy "rubbing" sound...
it may need a good lubrication job. look for all rolling parts metal or plastics and give a good dose of WD-40 and observe. ba particular to the bushing of the drive motor, the roller and the center bearing that hold the drum.
Feb 17, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
129 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
