Question about Olympus Camedia D-380 Digital Camera
Deleteing I want to delete unwanted pictures on the card . I have already downloaded them
    Sergeant:
  • 359 Answers
Under My computer when you have the camera hooked up, it should display as a drive, such as G: , I: etc, right click on it and select format, MAKE SURE IT's the camera!!
Posted on Sep 02, 2008
How to delete if internal memory card full
Hi
You can either download photo, data files to a SD card, another device (computer) or simply delete unwanted data by using the file brower. Locate, the unwanted files in storage, camera, or certain apps folders, & delete files. Don't delete any file in system folder. Hope this helps. Regards Bob from OZ
Jul 27, 2014 | tmax White 8GB 9" Android 4.2 1.6 GHz,...
Www fixya com support
Search the web for a free program called Recuva. Download and install it on your computer. Plug your SD card into a card reader and connect it to a USB port on your computer. Run Recuva and follow the instructions to recovered the deleted pictures from the SD card. This will only work if the card has NOT been used since the pictures were deleted. If the card has been used, the deleted files may have been overwritten and they are gone.
I've used Recuva to find and recover pictures that I have deleted from my recycle bin when I emptied it. Try to download the program from the Recuva site since many of the download sites now try to slip stuff you won't want into their downloads. Be careful to uncheck any boxes that attempt to add automatically things like toolbars, search engines and other unwanted programs.
May 22, 2013 | Nikon D70s Digital Camera
How do I delete pictures when the camera will not display them
Hi can you take the memory card out and look at them on a pc or laptop ? if so you could delete them there.
You could delete everything on the card by formating the memory card.
Sounds like there is some sort of problem with the card or camera if you cant see the pictures. Can you see any pictures on the camera? Do you have another memory card you could use to do a few test shots on and then see if you can delete them.
May 30, 2012 | Nikon D60 Digital Camera
Im having problem deleting unwanted pictures on my Samsung ES75 it took 45-60 seconds just to delete 1 picture. Can you please tell me the solution? Thank you.
If you are looking for an easy way to delete all the pictures at once, this is it....go into the menu and find "format"...follow the on-screen instructions to completely erase the card.
Feb 12, 2011 | Samsung ES75 Digital Camera
I have about 400 pictures on my memory card right now, and i need to delete them all for more room, but i can only delete one picture at a time! is there any way i can delete them all at once? i already...
To clear the card completely, format it. In fact, memory cards should be formatted each time you finish downloading the pictures. This prevents the fragmentation that occurs if the pictures are deleted individually.
Since you didn't specify the make and model of your camera, I can't give you specific instructions on how to format the card. It's probably somewhere in the camera's setup menu.
Dec 25, 2010 | Cameras
How do you delete multiple images from camera?
Are the pictures on a memory card? In that case, you're much better off formatting the card. If you continue to delete unwanted pictures, you'll fragment the card and ultimately you'll have problems. Every day somebody posts here with that problem. Formatting cleans things up.
If the pictures are in internal memory, select Internal Memory Tool from the Setup menu, and you can format the internal memory, deleting all the pictures. My earlier comments hold true here as well.
If you insist on keeping some pictures and deleting others, then go into the index (thumbnail) mode. Press the trashcan button, then select [Select] with up/down, then press *. Select images with the arrows, then press * to display the delete indicator on the selected pictures, Press the trashcan, select [OK], then press *.
May 13, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
How do I delete the unwanted pictures that have been downloaded onto my laptop?
Right click/delete!!
If you have a lot you can hold down the ctrl key and click on each picture you want to delete. This will highlight each one you click on then let go of ctrl key/right click on any of the highlighted pictures and delete. Don't forget to empty recycle bin.
Aug 25, 2008 | Computers & Internet
In my canon mp navigator 3.0 I can't delete any pictures so they just keep saving. How do I delete unwanted pictures in the MY BOX section?
Solution to deleting unwanted MP Navigator pictures...just go to the image you want to delete, then right click on it. A dialog box will pop up that has a delete button. Deleting will send the image to the recycle bin, where you can either empty the bin or restore the photo if you deleted the wrong one.
Jul 08, 2008 | Office Equipment & Supplies
Deleting pictures from cybershot viewer
Emmmeee,
I had the same problem with my digital cam/corder! An alternative solution to deleting pictures off the camera is, trickily enough, through your computer! This may be a bit of a hassle as you have preloaded your pics. What you will need to do is redownload your pics. You should be asked the option of deleting your pictures after download, and you click on the box.
Feb 07, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Olympus Camedia D-380 Digital Camera Logo
49 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
