Hi Error
code F1 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance. Daniel
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board. I would need the entire model # on sticker on the oven to see what parts are on this one. If the touch pad is separate it will have a ribbon that goes from it to the board. Unplug that ribbon, if the code goes away then the touchpad is the problem. If the code stays with the ribbon unplugged then the control board is bad. Make sure power is off to unit when touching anything!
