Question about Asrock 845GV (P4I45GV) Motherboard
I HAVE A ASROCK P4i65G MOTHERBOARD
I need some help and guidence with connecting the case power, im using an atx case and connot get any power to the board.
  • Anonymous Sep 29, 2008
    vga card
    Brigadier General:
  • 5,158 Answers
You can get the manual here
http://www.asrock.com/support/download.asp?Model=p4i65g
chose the specific model you are using.
Robert
Please rate this solution .... thanks
Posted on Sep 02, 2008
  • 797 Answers
Hello d0tc0m:
First make sure you have disconnected everything from the mother board...all cards removed, unplug anything on the board such as external fans and so on.
(what can happen is if something is shorted, your system will not start).
Test it then for a short time, if the same thing, then proceed.
A couple things you may consider.
Test the power supply with another board.
Use another power supply.
What you would be doing is by trial and error and elimination.
thanks, take care.
Power switch hook-up
You can use a manual switch off a computer and connect to the on and off switch on the motherboard.
Dec 21, 2009 | Asrock P4i65G Motherboard
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
On/off connection
ftp://europe.asrock.com/manual/P4i65G.pdf
There is the manual, on page 18 you can see where to connect hte pw-led and the the pwr that ist the frontpower connectors.
And here is the support site for you mobo, in case you need updated drivers for it:
http://www.asrock.com/mb/download.asp?Model=P4i65G&s=478
Good luck
Nic
Apr 17, 2009 | Asrock 845GV (P4I45GV) Motherboard
Wiring connection schematics
Here is the link for the Users Manual for the ASRock P4165G.
http://download.asrock.com/manual/P4I65G.pdf
This next one is for the quick installation guide.
http://download.asrock.com/manual/qig/P4I65G.pdf
Hope this helps. And Happy New Year to you too!
Dec 31, 2008 | Asrock Computers & Internet
Asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Jun 02, 2008 | Asrock Computers & Internet
Asrock P4i65G Motherboard Connections
Link
#26 is the Audio header for front panel
Jun 01, 2008 | Intel Motherboard
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
Motherboard is dead!
Here is a new board. http://3btech.net/asp4so47880p.html but you have 90 days to set it up & test it.
To answer you're question. (Yes it will fit). Both boards are Micro ATX.
Here are links for both boards showing their specifications.
Asrock P4i65G
http://www.dealtime.com/xPF-Asrock-Asrock-P4I65G-skt-478-i865G-800FSB-dual-ch-DDR400-8x-AGP-64MB-on-board-VGA-SATA-RAID-LAN-USB2-0
Asrock P4S61
http://www.dealtime.com/xPF-Asrock-ASRock-P4S61-P4-SIS-661FX-DDR400-Motherboard
This is ASRock's web site for the P4i65G
http://www.asrock.com/mb/overview.asp?Model=P4I65G
If I can be of more service, just post back & let me know how thing go.
Mike
Apr 28, 2008 | Asrock P4S61 Motherboard
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Asrock 845GV (P4I45GV) Motherboard Logo
124 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
