Question about Dell Inspiron 2200 Notebook
Key Board Some keys on the keyboard does not work. What could be the cause?
    Genius:
  • 1,239 Answers
Hi sir..
whether the antivirus is updated..
Posted on Sep 02, 2008
Keyboard locked on m14x laptop
replace the key board it doesn't cost so much
Mar 10, 2012 | Dell Alienware M14x Notebook
My computer is dell inspiron,the letter 'd' in my keyboard is not working,and when i'm turning on my computer for the first time,always letter 'd' is being typed by itself
If this is a wired keyboard (USB or PS2) then turn off the computer. Unplug the keyboard, and bang it against your palm to work some of the debris out of the keyboard. Now check the d key and make sure it bounces back when pressed.
You might also take a small screw driver and pry the d key off the key board and see if there is anything sticky on it. If so try cleaning with alcohol.
Last ditch effort before replacing the keyboard completely: Run the key board under running water to rinse it. MAKE SURE YOU LET IT DRY FOR A COUPLE OF DAYS (KEYS DOWN) BEFORE PLUGGING BACK IN. I have had this method work more than once. If it works its great if not, then non of the key board will work.
Jul 20, 2011 | Dell 0Y3740 Keyboard
When booting I get an error message key board malfunction, press F1 or F2 to continue but the key board doesn't work
try cleaning your keyboard of dust because dust causes static which can cause lots of problems to a computer or make sure that your keyboard connection is secure +control panel,computer management,device manager scroll down to keyboards if a yellow question mark?right click update driver
hope this helps good luck
Sep 07, 2010 | Dell (2336V) Motherboard
Keys that have Alpha and Numeric always show numeric and not alph
Try replacing the keyboard. sounds like a button is stuck and is causing the problem.
Jun 03, 2010 | IBM ThinkPad T41 Notebook
My Key Board is Not Working
The swapping process you have used already have clearly shown that your keyboard is faulty. It may be that a key is pressed down permanently / faulty and this blocks the signalling - check all the keys carefully to ensure none is depressed. Or one of the Connector pins (the part that goes into the computer) is bent - you may need to check and use a tool to straighten it.
But it is good to know that Keyboards are cheap to replace. If the above did not help, you can buy another keyboard for as low as £5 and then continue enjoying your computer.
Apr 30, 2010 | Lenovo Keyboard
I bought an emachine computer in January. 2 weeks ago the keyboard quit working. I tried another keyboard and that does not work either, what do I do.
to find the problem with key board & mother boarb Slot....? if u r key board usb port than conect another port restart the pc. key board not responding and the problem with key board. replace it
Mar 18, 2010 | E-Machines eMachines Desktop PC
My zero key on my macbook will not work
Never been inside one of those keyboards but many keyboards have a printer circuit board with plastic film layers over the circuit board. There may still be juice trapped in the layers shorting out the key or you may have burned out the key when it shorted out. I've seen that many times on Microsoft keyboards. You can always take the keyboard apart and check out the 0 key.
Sep 23, 2009 | Computers & Internet
Keyboard problem. Key 3, @, #, y, n can't use
you may have shorted your keyboard (spillage??)
if your laptop is outside warranty you can check the connection to the keyboard, by removing the top bezel, undoing the keyboard retaining screws and then check that the ribbon cable for your keyboard is seated properly, If reseating this cable does not work the you can always order a replacement for your keyboard, you can find the part number for the keyboard you have, it should be printed on a tag on the reverse of the keyboard.
May 24, 2009 | Acer Aspire 3680 Laptop
Spacebar
Well if the sapce bar on the key board is not working.... you can try to use the keyboard on another system & see if the same key works if it still dosen't work.. then go ahead & replace the key board of your system..
Jan 24, 2009 | HP CPQ175KB Keyboard
The "Ctrl" stop working
When one key stops working in a Keyboard there is dirt or some other obstruction between the contact layers and the board needs to be dismantled and cleaned or the contact layer has been broken and the keyboard will not respond to that key any more. The first is more likely unless the board has been really abused.
May 28, 2008 | Logitech 967437-0403 Keyboard
Dell Inspiron 2200 Notebook Logo
24 people viewed this question
Alun Cox
