My new Samsung flat panel lcd tv often has a horizontal line continually moving vertically and also a groaning noise; this occurs especially when a set of lights (close to tv) with energy-saving bulbs and a dimmer switch is turned on! Can you suggest as to how to get rid of these problems. Thank you. - M K Paul
  • mrinalpaul Sep 03, 2008
    The answer needs further clarification for a lay man e.g. what is a power filtered strip, where do you find it and how much should it cost? Do the problems indicate that Samsung has not taken all necessary measures to make my tv fully noise proof? Definite answers to all these questions will be of great help to me. Thank you.
    - M K Paul
    Master:
  • 521 Answers
Due to the heavy load on your single phase unit it creates this problem when other devices are powered ON on the same track. to get rid of this u need to have atleast the double phased power supply to take the load of all the devices.nothing to worry everything is normal.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
    Brigadier General:
  • 6,966 Answers
At best described, your unit is getting RFI (radio frequency interference) or basic electrical noise. Such could be brought about by other electronic devices physically near the Samsung flat panel LCD TV which may include (but not be limited to wireless phones, electronic ballast of florescent lamps, VCR/DVD/Gaming consoles with Channel 3/4 outputs.
Possible corrective actions:
  • the simplest, move such devices away;
  • try using a power filtered strip;
  • try plugging other devices in another wall outlet.
The technically correct procedure would be to improve the shielding of all these devices including the Samsung but that would be beyond normal user actions. Additionally, it should have been addressed in the manufacturer's design in the first place.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 04, 2008
    Hi again,
    Appreciate your postback.
    • what is a power filtered strip, where do you find it and how much should it cost?
    a filtered power strip is a multiple outlet that has an electrical filtering. It is designed to reduce if not eliminate any electrical noise entering an electronic device through the AC plug/cord. Here is an http://www.electronicplus.com/images/pro..." target="_blank" rel="nofollow" >example and they are often used with computers. Your choice of course should match your regions electrical system/requirements.
    • Do the problems indicate that Samsung has not taken all necessary measures to make my tv fully noise proof?
    most manufacturers would design their system to counter such electrical noises. It is unfortunate however that not all noises could be prevented. This is because (as in your Samsung), it has multiple entrance points which the unit could not do without, the AC cord, the CABLE/RF IN and the Audio/Video IN. Electrical noise could be prevented with adequate shielding but at most is a compromise. Some noise piggy ride on the AC power, the incoming TV signal and on the Audio/Video signal.
    In your particular concern, the noise is electrical produced by the switching electronics of the dimmer. Technically, it could possibly be a triac switching on & off the supply to the energy-saving bulbs at such a high rate, the effect of which is to reduce light level. Another possibility is that the energy-saving bulbs are using an electronic ballast that produces high frequency high voltage.
    Having said as much, the only options then would be:
    • relocate the dimmer (if wall mounted, of course impractical);
    • relocate the TV;
    • try powered filter strip;
    • replace the dimmer with an ordinary on/off switch;
    • replace the energy-saving bulbs with some other model/version that do not use an electronic ballast.
    Cheers.
Vertical and horizontal lines on samsung plasma tv
Check the Vs and VA voltages to plasma panel. If these voltages, that comes from the main power board is abnormal, this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 19, 2016 | Samsung Televison & Video
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
LNS4695DX/XAA Samsung tv vertical and horizontal lines on picture - all components
Thats usually caused by the Tconn board and or its connection also samsungs have been plauged with tab bond issues with the LCD panel itself. Send a pic of the issue to customerservice@tvrepairworld.com and they will be able to tell you whats happening with it be sure to include the model number with the pic
Mar 13, 2012 | Samsung Televison & Video
Faint black lines going from top to bottom when tv is on for about the first 15 min
If I'm understanding this correctly, you have a faint line, horizontally on the screen that moves vertically right? if so, It's AC noise. If you are mechanically inclined, the quickest fix is to replace your current AC outlet with a GFI outlet. Works 99% of the time. Hope this helps.
Jan 13, 2011 | Samsung UN60C6300 60 in LCD TV
My P50 vizio hdtv has horizontal and vertical lines running thru the screen....I was wondering if this is an expensive repair.thanks...Kahuna
Lines through a flat panel (especially moving or flashing lines) are indicative of a faulty power supply. Take it to an electronics repair shop. Should cost about $130.
If the lines are static (not moving), then you've got a problem with an image processor or the column drivers- the cost can vary wildly for the image processor. If the column drivers are messed up; you need a new tv.
Sep 05, 2010 | Televison & Video
Noise and horizontal line
Very easy Fix, The problem is the cable box is not grounded properly. (not your fault) Go to the Local store and get a Plug adapter, just to change the TV plug that goes into the wall or surge protector from 3 to 2. Trust me on this....
Best regards
CircuitCity
Nov 29, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
