Question about Microsoft Xbox Console
Xbox hard drive
Can a hard drive be salviged and reused from the same system?
  • 21 Answers
Yes it can...you would need to have the HD unlocked and you can do this by looking on the net!
Posted on Sep 02, 2008
Serial no 359146794305 what is its capacity
Microsoft has shipped numerous variations of the Xbox 360, with the major difference between each one being the hard drive size. As a result, your Xbox 360 can have a hard drive size as low as 4 GB and as high as 250 GB. If you're unsure of the size of your Xbox 360's hard drive, or just want to see how much space is remaining on it, you can check from the Device Options screen. This screen is accessible from the Xbox 360 dashboard when using any Gamertag.
Step 1 Select the "Settings" tab from your Xbox 360's dashboard.
Step 2 Select "System" and select "Storage" from the onscreen list.
Step 3 Highlight your hard drive from the onscreen list. By default the name of the hard drive is "Hard Drive."
Step 4 Press "Y" on the Xbox 360 controller to access the Device Options screen. The right side of the screen lists both the overall size of your hard drive under "Capacity" and the remaining amount of space under "Free Space."
Tip
  • From the Device Options screen you can also give your hard drive a custom name, clear the system cache or transfer content to another memory device.
Oct 06, 2015 | Microsoft Xbox 360 Console
Error 40a3-0000-3080-0502-8007-045d
I got this from the Xbox support site for your error code.
Error Code xxxx-xxxx-xxxx-xxxx-8007-045D
A storage device (such as a memory unit or hard drive) was not found during the software update. Follow these steps:
  1. Turn off your console.
  2. Remove all console storage devices, including any USB flash drives, external hard drives or the internal hard drive on the Xbox 360 E console or Xbox 360 S console. Learn how to remove the hard drive.
  3. Add your primary storage device, for example, the hard drive.
  4. Turn on the console
  5. Try updating the console again.
Here's the website if you wish to peruse it further.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Post back how it works out!
Jan 06, 2014 | Microsoft Xbox 360 Console
X-box 360s brand new, cannot get it to download the update
Hello
The easiest option to update the Xbox 360 hard drive is to connect to Xbox Live. The console will automatically prompt the user to install any available updates. Alternatively, users can download the update files to a USB flash drive to transfer to the Xbox 360 hard drive.
Update via Xbox Live
Open the Xbox 360 dashboard menu. This menu automatically appears when the console is turned on. Press the "Xbox" button, followed by the "Y" button to return to the dashboard menu from a game.
Scroll up to the "My Xbox" tab of the dashboard menu.
Select "System Settings" from the "My Xbox" section of the dashboard. Scroll to the right while the "My Xbox" tab is selected to reach the "System Settings" icon.
Select "Network Settings" from the "System Settings" menu.
Select "Test Xbox Live Connection" from the network settings. A prompt will appear to update the Xbox 360 hard drive if your system is not already updated to the latest version.
Select "Yes, update now" to install the latest updates to your Xbox 360 hard drive.
Updating via USB Flash Drive
Copy the update files onto the root directory of your USB flash drive. You can download the Xbox 360 update files by going to download.microsoft.com/download/1/d/8/1d8c09be-278e-41cd-98be-eb9188128227/$systemupdate9199.zip. You must extract the files from the .zip file before placing them on the USB drive. The update files cannot be placed into a folder or the Xbox 360 system will not recognize them.
Remove the flash drive from your computer.
Insert the flash drive into the USB port on the Xbox 360 console.
Turn on the Xbox 360. An update prompt will appear when the system powers up.
Select "Yes, update now" to update the Xbox 360 hard drive.
Nov 21, 2010 | Video Game Consoles & Games
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
XBOX System error E68
my friend suffered like these doubts....... he cleared his problem with the help of xbox 360 repair guide...... click here for your reference
May 08, 2010 | Microsoft Xbox Console
Xbox 360 Hard Drive Device (HDD) deleting content
Reformat the hard drive using the Xbox 360 system. If this does not work, then it is time to get a new hard drive for your system. We sell 20GB hard drives for the Xbox 360 so you can contact us and we'll be glad in helping you.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Microsoft Xbox 360 Console
Can i put my x box 360 hard drive on an xbox arcade.
I assume you mean the XBOX 360 Arcade system.
Your 360 hard drive will work on all 360 systems.
It does not matter if you have a Pro or Elite or Arcade system, the Hard Drive is the same.
Dec 29, 2009 | Microsoft Xbox Console
Halo3 Problems
Is your disc scratched?
Check to see if any accessories are causing the problem loadTOCNode(2, 'whattotry'); Turn your console off, and then remove all the accessories that are attached, including the Xbox Hard Drive. Turn the console on to see whether the problem still occurs.
  • If the problem does not occur when the Xbox Hard Drive is disconnected, try clearing the Xbox 360 Hard Drive cache. To clear the Xbox 360 Hard Drive cache, follow these steps:
    1. Re-attach the Xbox Hard Drive.
    2. Locate the System section of the Xbox 360 Dashboard.
    3. Select Memory, highlight Hard Drive, and then press Y to view the device options screen.
    4. On the Xbox 360 Controller, press the X button, press the X button again, press the left bumper, press the right bumper, press the X button, and then press the X button again.
    5. You will be prompted to confirm system maintenance. Select Yes by pressing A.
Jan 24, 2009 | Microsoft Xbox 360 Console
Freezing during oblivian
Oblivion uses the Xbox 360 hard drive to cache game data and in some cases the info stored on the hard drive can get fragmented, slowing down the game's performance. Bethesda has already found out a way to fix the issue. Here is the official word: Oblivion uses the Xbox 360 hard drive extensively to cache (copy and reuse) game data. This is done to optimize all loading the game does. It has been found in rare cases on some Xbox 360s that the cached data can get overly fragmented. This exhibits itself by the game taking a long time to load anything from menus, dialogue, sounds, objects, levels, and more. To solve this problem, reset your Xbox, and hold down the A button as the game is booting up. If any button is held while Oblivion is loading, it will clear its hard drive cache, and create a new one. Once you see the ?Bethesda Softworks? logo video, the game is already loaded, and the cache should have been cleared. Note, this does not effect your game in any way other than loading. You will not lose any saved data.
Jul 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
