Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Refill instructions for cartridge LC51Y for a brother all in one
HELP I do not know which of the two ports I should fill to.
  • 124 Answers
These printer cartridges are very hard to fill without special equipment. I suggest that you might buy refilled cartridges from the following: www.monstertoners.com You can purchase a package that includes 4 black and two each of the three colors for $39.95 plus s/h.
Posted on Jan 26, 2009
How to refill Brother LC101 ink cartridges
many manufacturer's have made the cartridges so they can not be refilled , but only replaced with OEM cartridges . they chipped them .
Apr 14, 2016 | Brother LC101BK Ink Cartridge
Torner ended in brother dcp1511
This machine uses a Reset Gear to instruct the printer it has a new cartridge. The Starter Cartridge that comes with the machine does not have this gear attached to it so refilling the cartridge without installing and resetting the gear will not allow you to print normally.
If you are using a store bought cartridge that you have since refilled you can reset the gear to tell the printer it is a new cartridge.
Oct 30, 2014 | Brother DCP Office Equipment & Supplies
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
How do I refill my ink cartridges?
If you bought an ink refill kit, then there should be a bellows with a fine needle tip filled with ink and a rubber stopper. There should have been instructions included with the kit.
If you only bought the bellows and there's no instructions or rubber stopper, then I'm afraid you are missing some pieces. You need more than just the ink to refill the cartridges correctly, or else they will leak all over the inside of the printer.
May 11, 2009 | Brother MFC-260C All-In-One InkJet Printer
Refill brother LC51Y inkjet cartridge
see here:
http://www.hstt.net/refill-faq/brother.html#LC-1000%20-%20Refill
(use google translation german)
for c/y/m refill 15ml dye ink
for bk 20ml
Apr 22, 2008 | Office Equipment & Supplies
How To Refill?
Harry, you can use every DYE ink for brother printers. DO NOT use pigmented ink due to clogged filters inside the printhead!!!! The carts for mfc210 are filled with 20ml for BK and 11ml for C/Y/M. I use to refill 20ml only ink for bk and 10ml ink + 1ml printhead cleaner for C/Y/M. See here how to do that (LC900 refill): http://www.hstt.net/refill-faq/brother.html#LC-900 Refillen (Simply drill a hole into the brother brandname and leave it open!) I use a 20ml syringe and 3 12(10+2)ml syringes from the drugstore (ask your doc! It may be cheaper ;-)
Sep 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
How to refill the cartridge of brother MFC240c
Hey its very simple, you'll need a syringe and an exacto knife. You just need to pop the case in half use the exacto knife to cut the seem very carfully and to pry the cartridge apart carfully. On the back of the cartridge you'll see a little indintation were it was filled in the factory just fill the cartridge with a syringe push in the indintation fill cartridge remember to leave a little air in there and seal the hole up so it's air tight again this can be done by using a little hot glue to seal the hole. I hope I was helpful. As well you can by a continous ink system for the brother 240c which is pretty need too
Sep 08, 2007 | Brother MFC 240C All-In-One InkJet Printer
How can I refill my ink cartridges myself?
Be brave and have a go, buy the correct ink refill for your selection of cartridges, the packaging on the refill kits will tell you if your printer is included. Once you find one for yours, instructions come with it. I think your cartridges have plastic ones don't they? Make sure when you fill with syringe you follow instructions very closely to avoid air bubbles and always run a clean when you put it back in. I refill all the time, and each time i refill (i get 7-8 refills each cartridge now the way i do it) i am saving $80.00 both cartridges. This can be most of a thousand dollars a year for me.
Aug 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
202 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
