Question about SanDisk Sansa e250 MP3 Player
E.q. when i try to set my eq to custom. i have to go back to it after every song and move one of the bars up or down to get it to kick in again. and i have it set the same as another in the house and it sounds like **** any suggestions?
  • 8,596 Answers
If your songs are coming from more than one source, or you are using a pure file sharing program like Limewire, Morpheus, Frostwire, etc., every mp3 is recorded at different levels. You will have to become a bit of an audio editing expert to do this, but you will need to get audio editing software, and set the elvels, bit rate, etc of all of the songs to exactly the same level - or else, you will get variable play quality on your custom EQ settings. WARNING: This is going to take a LONG time.
-Tha Mp3 Doctor
Posted on Sep 05, 2008
How do i adjust the EQ on the Eclipse 180G2
These answers are not even related to the problem. He wants to customize the equalizer, which is *clearly* an option. However, our Eclipse 180g2 players are not allowing us to switch bands, so we can only adjust the first bar of our equalizer.
How do we switch bands and fully adjust the equalizer?
Nov 28, 2013 | Eclipse Audio Players & Recorders
I have lost the Instructions for my portable CD/MP3 player. I simply need to know what the various buttons do: Mode: 10+Album:Skip/Search: Play/Pause: Stop :Eq/Prog : Vol+-
mode: for repeat
10+Album: to change song more than 10 like 11 19
Skip/Search: press one time will go to next song press and hold search the song
Play/Pause: start playing song or make it stop
Stop : stop the song you are playing
Eq/Prog : setting menu
Vol+- increase or decrease the sound
Jul 29, 2011 | Audio Players & Recorders
Sound Problem
Sounds like something's up with your EQ. From the main menu, go to Music>Music Options>Music EQ and try another setting or play around with Custom. Could also be volume. Go to main menu>Settings>Reset All (NOT FORMAT!!!) Recommend trying both in given order. Hope this helps.
Jan 06, 2010 | SanDisk Sansa Clip MP3 Player
Zen V Plus is locked up, won't shut off
EQ is something you can set up to make the sound of your songs better..well, sounding. It can add a base boost, vocals clearer to hear, etc. It won't effect your player or music. You set that on yourself. Ex: I have EQ by my battery sign b/c I set the EQ on "New Age" in the System. (You can take it off by going into system, and going to audio settings.)
I just recommend that you should try letting the battery run out, and it will most likely reset itself. My player did that too, and I totally freaked out. I thought that it was broken, but I hooked it up and it just needed to be docked.
Feb 12, 2009 | Creative Labs ZEN V Plus MP3 Player
EQ settings
This setting is a blast,I adapted it from the 10 band "perfect" itunes eq setting. don' t be shy , give it a try...
80hz = (2) or 7
220hz = (0) or 5
470hz = (-1) or 4
1khz = -(-2) or 3
2.2khz= (0) or 5
4.7khz =(2) or 7
12khz= (4) or 9
I have this on my LG tv, however if you need more oomph! to it, simply stick to the same pattern between the two sets above and move each slider up accordingly.
Sep 26, 2008 | Car Audio & Video
Creative Zen Nano plus -512 MB
well it shouldnt play the first song in the folder. it should automatically play the song where you left off. and when you are changing the EQ, make sure that you are pressing in the selector key. (the key at the bottom to the right of the volume control keys) as it may take a while to adjust to your volume settings
Jul 09, 2008 | Creative Labs Zen Nano Plus MP3 Player
After reset my sansa in recovery mode have lost a setting
Update your firmware.
Firmware Update
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Oct 28, 2007 | SanDisk Sansa e250 MP3 Player
Custom eq problem
Contact Sansa tech support directly to inform
May 23, 2007 | SanDisk Sansa e260 MP3 Player
Does anyone think if the Equalizer presets of iPod sufficient?
Hrm..... This is a tough issue. I have experienced this as well. I can't really solve the problem, I can only share what I have done personally to deal with this. Hope this helps. I have settled on: 1. Leave the iPod's EQ on default and don't change it. 2. Change certain songs that must have EQ help individually. 3. Set the maximum volume setting on the iPod to the highest setting. 4. Assess where and how I listen to music on my iPod and plan to get headphones that work with my listening style. 5. Get better headphones. They don't have to be expensive to produce good sound quality. 6. If you connect it to a speaker dock or a stereo system use it's built in EQ/DSP.
Apr 16, 2007 | Apple iPod MA446LL/A MP3 Player
Help!!!!!!!!!!!!!!
can you still switch the MP3 player on? if so... 1)Switch the MP3 player on and go to 'SETTINGS' 2)Try to restore the factory settings. This will NOT make the songs disappear from your MP3 player, but will reset the Custom EQ settings if you used them. I hope this helps.
Jan 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
