Question about Kitchen Appliances - Others
Microwave Power Relay
I have a GE built-in microwave and the power relay is bad. Trying to find an 18V relay Omron G5J-1-TP-M-DC18 or compatible. I can't seem to any available relays. Thanks
Http://www.onlinecomponents.com/buy/PANASONIC-EW-AROMAT/ALE72B18/
Posted on May 01, 2010
  • 9,098 Answers
G5J-1-TP-M-DC18 should be the same as G5J-1-TP-M-ER18, which is found in Panasonic commercial microwave ovens.
Even if there are slight physical differences, most microwave boards have extra holes so different relays can be used.
In more extreme cases, a comparable relay can be used if you drill a hole or two to fit it.
Then I always hot glue them in place after soldering just to hold them better.
The Panasonic part number is AEG5J1EM18B and you can get either in one of these two places: http://www.pasc.panasonic.com/epartr or http://www.wehaveparts.com
Posted on Sep 06, 2008
What does F6 error code for Whirlpool microwave model XCK4640802 mean
The F6 code is listed as a problem with the MW relay. Here are the testing steps from the technical literature. The relay that is mentioned is a part of the control so if the problem continues you will need to replace the control.
1. Unplug microwave oven or disconnect power.
2.Check the cable to Relay 4903.
3. Check to see if the relay (4903 on relay electronic control) contact has welded closed.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
6. If problem persists, unplug microwave oven or disconnect power.
7. Replace electronic control.
8. Replace all parts and panels before operating.
9. Plug in microwave oven or reconnect power.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Whirlpool Microwave Ovens
My over the stove microwave starts continues for a few econds the f-7 appears and it stops
F7 means power to magnetron is interrupted.
I don't recommend that someone without experience and an understanding of the safety procedures undertake troubleshooting this.
You can find manuals and helpful exploded view diagrams for your model here and my favorite parts supplier is here. There is a technical sheet hidden behind the controls that has helpful technical and troubleshooting information. It will say something like this:
F7 Power to magnetron interrupted
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Oct 05, 2016 | Kenmore Microwave Ovens
Only microwave not working
Chances are you have a bad secondary / cook relay on the control circuit board. The relay can be replaced. See details here.
Jul 06, 2013 | GE Advantium 120 Convection/Microwave Oven
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
I have a that microwave gh7208xrs that shows a error code F7 HVSMPS feedback
The controller is not getting the high voltage switched-mode power supply feedback signal.
Sometimes this is due to a defect on the HVSMPS (inverter) or a bad connection from the HVSMPS to the controller.
Due to the voltages involved, I do not recommend that an inexperienced person attempt to troubleshoot an inverter.
In the event that you or someone you know wants to look into it, see these safety warnings first.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It tells you this:
board.
Inverters."
I'd suspect 6 through 8 first.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jul 08, 2011 | Whirlpool GH7208XRS Stainless Steel 1200...
GE Microwave JVM-1190WY Is always on with the door closed. Need to open door to shut down,. Is the power relay stuck on?? Do I need a new power relay?/ Joe Ziomek 305-664-1221
Please check your e-mail. I answered this directly.
Jun 20, 2011 | GE JVM1190SS Microwave Oven
I have a GE 1650 black microwave and is not heating anything. I heated a potato and after it was finished, the microwave went off. Thought maybe a fuse, but not is goes on though nothing is being heated....
It is possible that your magetron is not working.First of all disconnect the power, open the top,if you had checked the fuse to be good then check the high voltage power capacitor and teh wores to the magnetron. If all these seems fine then a voltge check must be made when the set works in microwave mode. Put in a cup of wter and switch on. If the relay does not click along with the fan coming on , then the relay circuit must be checked. If you are not familiar please take help as it is dangerous to probe without any klnowledge. I am sure there cannot be anything serious than a failure of the one of these. hope my advice helps you out. Good day
Aug 02, 2010 | GE JVM1650SH Microwave Oven
I have ge spacemaker microwave heats but fans dont come on .
This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Feb 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not working
Nov 13, 2008 | GE JE1860 Microwave Oven
Kitchen Appliances - Others Logo
1,089 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
