Question about Home Security
ECHOVUE 405 I have an Echovue 405 DVR and the hard drive went out. What kind of hard drive can I use to replace it. The unit is over 3 years old.
  • 423 Answers
You should be able to drop any size hard drive in that unit. Unplug it and take the cover off. The hard drive will be screwed in to it's holder and will have a 40 pin ribbon cable and a power cable running to it. The drive will have the specs on it. Just google it and see what pops. Should be no problem.
Posted on Mar 04, 2009
Need to recover data from DirecTV R15 DVR receiver hard drive
First, sorry for the delay in respoding to your post. I did notice that you had a prior question about the Power Supply on an R15 DVR. Does the unit have a manufacture code of 500(found on the right hand front Flip Door of the DVR)? If so, I might be able to help you in repairing the Power Supply. As far as I know, getting your DVR up and running again is the only way to watch your previously recorded programs. As far as retreiving programs from your old Hard Drive via other methods, I probably won't be able to help you there. When I had both of my identical DVR 15 500's apart for a parts swap to diagnos a failed Phototransistor(infra-red sensor for the remote control), I also tried to swap out the Hard Drives. This is what I found: When you swap a Hard Drive into another DVR, it won't play any of the programs previously recorded. However, if you record new programs on the swapped Hard Drive then they will be playable on this current setup. Now, if you swap the Hard Drive back to the original DVR it came out of, the programs will once again be accessible except for any that you might have recorded while the Hard Drive was in the other DVR. So, in conclusion, when programs are recorded on a particular DVR, it is encoded electronically to play back only in that DVR via communication from the Motherboard and the Hard Drive. I know, it sucks, but that is why I was asking if you are pretty sure the Power Supply is at fault. If so, I received info from this forum on how to fix the issue. Also, if the attempt fails, Ebay has some previously owned DVR's for sale and maybe you can get one for spare parts. Remember, the Power Board and Front Display Control Panel are the only interchangeable parts IF you want to view the programs on your DVR's Hard Drive. Let me know what your DVR does when you plug it in. That will go far in further diagnostics of your DVR.
Nov 28, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
ViP 612 DVR hard drive is always running. I don't beleive it did this when it was new. At least I never heard it. It's about 2 years old. It is not the fan. The unit vents are clear. Tried reboot. No...
The function is always in use because of the ability to pause live tv and rewind. So its very common for the hard drive and fan to run often on DVR receivers. Does it still allow you to record programs? The best option would be to unplug it for 10-15 seconds which sounds like you have done. If the sound is becoming overbearing we can send a replacement receiver.
Nick Franta
DISH Network Customer Service
Jan 23, 2011 | DISH Network ViP 612
Hard disc failure How change hard disc DVDR 3330h
Have you solved your harddisk problem?
I have the same issue.
Dec 06, 2010 | Philips DVDR3330H DVD Player/HDD Recorder
I have Samsung SHR-1040 DVR in use for 3 years. It is giving a humming sound now which is annoying. All other function working OK. What could be the problem
There is a small fan in the back of the unit which might be rubbing or failing. It's a standard type of fan so any good computer parts store will have a comparable replacement. Or it could be the hard drive is beginning to fail. You will have to open the case to find out.
Mar 17, 2010 | Samsung 4 Channel Dvr
Won't turn on, just says "Hello" and will load no further
This is due to one of the IDE devices inside (Hard Drive or DVD drive) not sending the requires "I am Ready" signal to the main board while the DVR does a power on self test. With the hundreds of units I have come across, 99% of the time it is due to a faulty DVD drive. These "Loader" brand DVD drives were on the cheap and when they give out, the unit does not go past the Hello. You can verify this by replacing the the DVD drive with any other DVD burner or DVD drive or even a CD drive that comes from a computer (IDE connector). The only fix for this is to replace the drive or simply connect an old CD drive inside and not use the DVD properties of the DVR, only the hard disk recording/playback.
Oct 01, 2009 | RCA DRC8030N
Whiny dvr
sounds like the hard drive in the dvr is bad - they're easy to replace though - just follow the steps below.
  1. Step 1 Disconnect your DVR by unplugging any cables connected to it, including the power cable. Remove the screws located on the back of the unit that hold the top cover in place. There are usually two to six of these screws, depending on the model of DVR. Lay these screws in a safe place where they won't get lost, and slide the cover off.
  2. Step 2 Locate the hard drive. This is a rectangular metal unit that measures 3 1/2 inches wide. It is usually located away from the other hardware, often in its own bracket. There will be two to four screws holding it in place. Remove these, disconnect the cables connected to the drive, and slide it out of the system.
  3. Step 3 Check the label of the drive to see if it is IDE or SATA. It will say which one of the two interfaces it uses. Any replacement desktop hard drive of the same interface type will work in your DVR. Avoid using a laptop drive, because they won't fit and aren't designed for the high-stress environment of video streaming.
  4. Step 4 Place the new drive into the brackets, and replace the screws that were removed from the old one. Plug the data and power cables into this drive. They will insert the same way they came out of the old one. Once the drive has been installed, put the cover back on the DVR unit, and replace the screws. Hook the DVR back up to the television, and it will be ready to record.
Sep 12, 2009 | Cyberhome DVR 1600 DVD Recorder
Can I get my recordings off a HD DVR with a damaged hard drive?
Sorry, no. Not unless you have a working unit you can put the faulty drive in, but as you say, it's faulty... by its nature a faulty drive isn't useable.
Aug 20, 2009 | Directv HR21-700 DTV Receiver
External hard drive connection through the dvr station
i have the same problem. as far as i know it is because large external hard drives require more power and the archos does not provide enough power. it would probably work if u got a hd which had a separate power source.
Jul 28, 2009 | Archos Internet Media Tablet MP3 Player
Zone code for Yamaha DVR-S150 Cinema Station...
Most of these units are made for regional use only. Contact Yamaha.
Dec 21, 2007 | Yamaha DVR-S150 DVD Player
Home Security Logo
226 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
