Question about LG Flatron L1750S 17" LCD Monitor
LG Flatron L1730s
My problem is that the monitor works but not when you want it to.
The screen when first turned on blinks for less than half a second and then goes dark again.
 have to turn the monitor on for at least 1hour before i want to use it as after one hour elapses, it begins to work. however, at somepoint, it has to go off right? i can't leave it on forever! next time of usage the same story gets told.
every time the screen is turned off and on it blinks once and then turns black. I know the CPU works as i see it flash when the screen does. Now it takes 5 hours to come on. so now i have to turn it on 5 hours before i want to use it.
i just want to know if this is worth keeping and trying to fix? or should a just buy a new monitor? even if anyone has any ideas as to what is wrong with it i shall be very grateful because at the moment i'm lost with this thing
thanks jeremy
  • Anonymous Feb 28, 2009
    The same problem
  • Anonymous Mar 03, 2009
    Mine does this, but I never turn my monitor off...the problem starts after I haven't used the computer in a few hours. I have to turn it off and on over and over while it just blinks, after a few minutes of this it will stay on. I'm worried it eventually won't come on at all.
    Brigadier General:
  • 6,966 Answers
Sorry for the delay in responding, it is just now that I was able to view your concern. Acouple of ideas:
  • possibly the CCF (cold cathode florescent) lamps, the inverter and/or the main board;
  • the blinking light is significant, it could indicate loss of video signal or internal protection kicking in;
  • possibly heat related, check for any of the capacitors bulging or leaking.
This of course would require opening the unit, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
If you are considering a DIY, pls reference a service manual or a schematic diagram, that would be chassis CL-82 for an LG L1750S. Foremost to check would be for the presence/consistency of both the 12 and 5 volts,.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 27, 2008
I dont have driver flatron l1730s lcd monitor . usb driver monitor
You may be able to download the driver from these WEB sites.
http://totallydrivers.com/device.php?id=74496&show_devs=a
http://www.bravofiles.com/driver-LG-FLATRON-L1730S.html
Apr 06, 2011 | LG L1730SF 17" LCD Monitor
I didn't get disply on my lg flatron l1730s lcd monitor
Connect it to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer's video-adapter is working.
Nov 06, 2010 | LG L1730S 17" LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Jun 13, 2009 | LG L1730S 17" LCD Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
No picture
you should take it back
Jun 21, 2008 | LG Prada KE850 Cellular Phone
LG Flatron L1750S 17" LCD Monitor Logo
423 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
