Question about Palm IIIe Special Edition Handheld
How do I hot sync my mail?
I'm using Palm Desktop 4.1.4 with a Palm IIIe. And I'd like to know how I can have Palm Desktop send my mail messages through outlook that are stored on my palm that havn't been sent yet. Previous software I've used had this option but I can't seem to find on in Palm Desktop.
  • 473 Answers
SOURCE: How do I get outlook & my palm to sync?
Hi, if u want to sync with outlook , u would either have to buy the installiation disc from palm online store or call up tech support , it will cost u, or if you want u call also chapura and buy the outlook conduits from them , u dont get the outlook conduits on the website . In the installiation disc u get the outlook conduits . Regards
Posted on Sep 11, 2005
  • 473 Answers
SOURCE: Tungsten E and Outlook 2003 sync problem
I also have encountered this: The issues, however, started after our enterprise at work switched the backoffice server from Win2K pro to 2003 server. All users received new Outlook profiles. I know there are hidden services for Palm bundled into the outlook profile so I simply edited the old profile to point to the new server and proceeded as follows: CPU was an HP Pavilion DV1000 laptop with Windows XP Pro SP2 with Outlook 2003 to a Palm Tungsten E PDA. Unit would not synchronize contacts or calendar, producing "Calendar Synchronization Failed" and "Contacts Synchronization failed" errors. Creating entries in outlook contacts and calendar did not show up on the Palm. Creating entries on the PDA did not show up in Outlook. To rule out windows profile corruption, I backed up the users profile data, deleted her windows profile and logged back in to create a new one, copied all of her favorites, documents and desktop information back to the new profile and tried again. No joy. I created a new palm profile to rule out issues with the users original Palm profile being corrupt or damaged. I verified the hotsync app was pointing to the correct palm and outlook profiles. To rule out issues with her outlook profile being corrupt or damaged I backed up her contact and calendar data, wiped that too and created an all new one and re-imported the contact data from a personal folder not connected to an exchange server. No change. I deinstalled and reinstalled the Palm software as well as the conduits for outlook. No change. I downloaded the new and improved conduits that were supposed to fix issues with outlook synch problems. No change. I finally backed up all of the data on her palm by creating a new outlook profile that was not connected to our exchange server at the company but rather a personal folder on the PC and once the data was saved there the data was imported back to the users mailbox. This didn't work but it allowed us to back up all the data on the palm and let us perform some experimentation with formatting the palm clean as a plate and trying anew with her account and profiles - no change. I found the errors only occurred when logged in as the user herself. If I logged in as me and started fresh from a reinitialized palm on her computer it would work. Amazing. I even found that creating a new local user account on the PC and pointing at her own outlook account on the mail server wouldn't work either.. But it would work for my own. After some brainstorming.... I believe that the issue is related to a corrupt e-mail box on the actual mailserver itself rather than an issue with the workstation or the palm itself since if I log in as myself, I can set it up and make it work. I can use a different account. It works. But it ALWAYS fails when we attempt to attach to the users mailbox on the server itself. So, some of these issues could be related to changes or problems on an Outlook mailbox th
  • 473 Answers
SOURCE: How to change the default handler from Outlook to Palm desktop?
Change sync methods from outlook to palm desktop !!!!! Hi, There are two ways to change the sync methods : 1. Insert the installiation disc into the cd rom device , u will get a window called dicover ur handheld , there please check for change ur sync methods , and u will get another window sayin ur currently using microsoft outlook to sync , would u like to change to palm desktop , say yes and then u will get congrats , click on finish . To make sure it is changed from outlook to palm desktop , right click on hotsync manager at the bottom right corner of the pc , make sure only local usb has a check mark and then left click on custom , in custom check and see if u see calender [outlook] or just calender , if u just see calender , then presuming all the data is in handheld , highlight calender click on change and change the action to handheld overwrites desktop then click on ok , do the same for contact , tasks and memo then click on done and perform a hotsync. 2. Insert the disc , open up my computer , then u will see ur cd rom drive , right click on it and left click on explore , u will find yellow folders , please check for a yellow folder called post install , open that up and inside that u will find outlook switcher , left double click on it and follow the same procedure as told in the first step . Regards
  • 473 Answers
SOURCE: Sync with outlook
Change ur sync method. To change the sync from palm desktop to outlook , insert the installiation disc in and then install the pocket mirror conduits conduits that will help u to sync with outlook .
  • 4102 Answers
SOURCE: Palm M515 hot sync problem
Hi you could either have a problem with the lead witch is the cheapest problem to solve the other problem is with the palm top itself if this is the case then you will need to send it off to get the firmware updated you cant do this yourself because you cant get the correct software to do this you might even need to put the device in recovery mode to install the latest firmware so it will need sending off to do this if you contact customer support number for your device then they should tell you the best way of doing this ok
Posted on Feb 11, 2008
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
0 characters
1 Points
When I hotsynch my palm zire IIIe a message appears telling me that the hotsync operation is complete, but it hasn't hotsynched properly, ie did not add recently added to computer addresses. However, it...
HI,
I had the same problem with my palm. The first thing I did was to make sure I had the most up to date software on my computer. YOu can get this by going to www.palm.com and cklicking on PDA's and then the name of your palm. From there it will bring up a page that has all the up to date desktop software. If you have the up to date desktop software and you have all your information backed up on your computer then preform a hard reset. This will ERASE everything on your palm. If you need directions on how to do this send me a comment and I will get those directions. If you ahve the manual it should tell in there how to do a HARD reset. The hard reset will restore it back to all the default settings and erase it just as if it were new,. After you get to this point do another Hot Sync. It hould sync for you just fine. Hope this works for you. I had great results doing this.
Best wishes.
Aug 21, 2009 | Palm Z22 Handheld
Data transfer
You can install palm HotSync application
from the following link http://palmone.r3h.net/downloads.palm.com/PalmDesktopWin414EN.exe
Once you Sync you will see the option to tranfer the contact items to Outlook
Good Luck
Jul 02, 2009 | Palm IIIe Special Edition Handheld
Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Jan 01, 2009 | Palm Z22 Handheld
Pda will not hotsync
assuming that you use your palm tx on a windows xp system, files from the emails could be corrupted. are you using palm desktop or outlook?
if you are using palm desktop, you can rename the back-up folder to old and try to resync
Oct 08, 2008 | Palm TX Handheld
I own a Palm Tungsten E2 when I go to hot sync I get an error message that states the connection between your device and desktop could be established please check your setup and try again
1. Go to your desktop program
2. Go to top and select HOTSYNCH
3. Select Set Up
4. Select the port your E2 is attached to
5. Theres more but I need to know how you are to this point or go to live tech support and ask for Just_Bobz
Sep 24, 2008 | Palm Tungsten E2 Handheld
Dec 20, 2007 | Palm m515 Handheld
Palm data and ActiveSync
You won't be able to do that. Lotus Organizer as well as Lotus Notes and OutHook are PIM some plus e-mail, just like Palm Desktop is a PIM. So you can have the Treo sync with Lotus Organizer AND have the Axim sync with it also it is because there are conduits buit for them. There is a middleware that allows both to talk to one. Now if you can find a piece of software out there that will sync a PocketPC with Palm Desktop, I'm sure a lot of Palm converts would love to know that.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Hot sync operation cancelled (8001)
Try replacing the cradle or if you can install Palm desktop on another computer and try synchronizing on it. This is usually a sign of a week cradle or COM port on your computer.
Sep 12, 2005 | Palm IIIe Special Edition Handheld
Cannot sync with outlook
You need the CD to get the Chapura PocketMirror Standard conduits. The conduits for Outlook are not part of the desktop download due to copyright protection. You need to obtain the actual CD by contacting palmOne tech support via phone. They will send you a CD for a small fee. If you happen to have a Treo 180,270,300 or 600, the desktop software download for these models includes Chapura PocketMirror standard version as part of the download but you need a serial number for one of those products to get the download.
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Palm IIIe Special Edition Handheld Logo
47 people viewed this question
Top Palm PDAs Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
