Question about ASUS A7S333 Motherboard
Rebuild existing desk top
The unit failed as my son left for Iraq and he ask me to rebuild it so his daughter here in the states could be in contact with him. It has failed to boot just before he left and I did not see exactly what happened. He requested that I rebuild it. I worked as a field tech in research and development for TI for about 30 years mostly in adverse enviroments overseas soI build my own desk tops here so I know the only two things I need to repair the unit is a manual andthe setup support disk. Can you help me? My email address is robcoate@msn.com --tel US 254-822-1476 address Robert Coate , 835 Bays Road, Axtell, TX 76624-1158 and my FAX is 1-208-730-5088. I WOULD CERTAINLY APPRECIATE YOUR ASSISTANCE IN OBTAINING THE ABOVE LISTED MATERIAL SO I MAY PROCEED WITH THE REBUILD OF THIS UNIT....I KNOW A LITTLE SEVEN YEAR OLD WHO WOULD CERTAINLY APPRECIATE IT.
Bob Coate
  • robcoate Sep 02, 2008
    Don't you even recognize your own Motherboard designations???? The A7S333 is a ASUS motherboard and I did not have much luck at finding any data on the ASUS web page.
  • 797 Answers
Hello robcoate:
The only thing I can tell you is go to the website of the maker of the mother board. Then try to find that model and number.
If all else fails send an email to the maker of the board, that may be a good thing to do anyway.
Then download the materials you need.
Also searching the internet may give you some help as well.
Take care,
Posted on Sep 02, 2008
  • Dave Lundmark
    Dave Lundmark Sep 03, 2008
    Hello:
    I don't have one like what you have described. I have had some Asus MBs over the years.
    You are asking for help.
    I am giving you free help. The Asus site would be the best place to go.
    Try this site and download what you need.
    http://www.driverstock.com/ASUS-A7S333-d...
    Go to this link. Then pick what driver and software you need for your operating system. Read the information given.
    Here is a Yahoo.com search:
    http://search.yahoo.com/search?p=asus+a7...
    Hope it works.
    take care,
I have a Gen 8 Hp server with 5No 600GB HDD. The first two disk are mirrored, the other 5 are on raid 5. 1 of the 3 on raid 5 is flagging amber colour. How do I replace the HDD without losing Data?
Before replacing drives • Be sure that the array has a current, valid backup. • Confirm that the replacement drive is of the same type as the degraded drive (either SAS or SATA and either hard drive or solid state drive). • Use replacement drives that have a capacity equal to or larger than the capacity of the smallest drive in the array. The controller immediately fails drives that have insufficient capacity. In systems that use external data storage, be sure that the server is the first unit to be powered down and the last unit to be powered up. Taking this precaution ensures that the system does not, erroneously, mark the drives as failed when the server is powered up. Replacing drives The most common reason for replacing a drive is that it has failed. However, another reason is to gradually increase the storage capacity of the entire system. NOTE: In fault-tolerant configuration, hot-plug hard drives can be replaced when server is ON, but in case of a Non-hot-plug hard drive, it should be replaced when server is OFF. For systems that support hot-pluggable drives, if user replace a failed drive that belongs to a fault-tolerant configuration while the system power is on, all drive activity in the array pauses for 1 or 2 seconds while the new drive is initializing. When the drive is ready, data recovery to the replacement drive begins automatically. For systems that support non-hot-pluggable drives, if user replace a drive belonging to a fault-tolerant configuration while the system power is off, a POST message appears when the system is next powered up. This message prompts user to press the F1 key to start automatic data recovery. If user do not enable automatic data recovery, the logical volume remains in a ready-to-recover condition and the same POST message appears whenever the system is restarted. Automatic data recovery (rebuild) When user replace a drive in an array, the controller uses the fault-tolerance information on the remaining drives in the array to reconstruct the missing data (the data that was originally on the replaced drive) and then write the data to the replacement drive. This process is called automatic data recovery or rebuild. If fault tolerance is compromised, the controller cannot reconstruct the data, and the data is likely lost permanently. Time required for a rebuild The time required for a rebuild varies, depending on several factors: • The priority that the rebuild is given over normal I/O operations (user can change the priority setting by using HP SSA/ACU) • The amount of I/O activity during the rebuild operation • The average bandwidth capability (MBps) of the drives • The availability of drive cache • The brand, model, and age of the drives • The amount of unused capacity on the drives • For RAID 5 and RAID 6, the number of drives in the array • The strip size of the logical volume • Firmware versions of the Smart Array Controller and Hard Disk Drive • Presence of BBWC/FBWC CAUTION: Because data rebuild time may go upto the rate of 200GB/15 minutes, the system could be unprotected against drive failure for an extended period during data recovery or a drive capacity upgrade. When possible, perform rebuild operations only during periods of minimal system activity. When automatic data recovery has finished, the drive status LED changes from flashing green to solid green. If the drive status LED on the replacement drive changes to flashing or solid amber, the rebuild process has terminated abnormally. If an abnormal termination of a rebuild occurs, identify the cause and appropriate corrective steps. Abnormal termination of a rebuild If the activity LED on the replacement drive permanently ceases to be illuminated even while other drives in the array are active, the rebuild process has terminated abnormally. The following table indicates the three possible causes of abnormal termination of a rebuild. Cause 1: An uncorrectable read error has occurred. 1. Back up as much data as possible from the logical drive. CAUTION: Do not remove the drive that has the media error. Doing so causes the logical drive to fail. 2. Restore data from backup. Writing data to the location of the unreadable sector often eliminates the error. 3. Remove and reinsert the replacement drive. This action restarts the rebuild process. If the rebuild process still terminates abnormally: 1. Delete and recreate the logical drive. 2. Restore data from backup. Cause 2: The replacement drive has failed. Verify that the replacement drive is of the correct capacity and is a supported model. If these factors are not the cause of the problem, use a different drive as the replacement. Cause 3: Another drive in the array has failed. A drive that has recently failed can sometimes be made temporarily operational again by cycling the server power. 1. Power down the server. 2. Remove the replacement physical drive (the one undergoing a rebuild), and reinstall the drive that it is replacing. 3. Power up the server. If the newly failed drive seems to be operational again: 1. Back up any unsaved data. 2. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. The rebuild process automatically restarts. 3. When the rebuild process has finished, replace the newly failed drive. However, if the newly failed drive has not recovered: 1. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. 2. Replace the newly failed drive. 3. Restore data from backup. More Resources: • Click here for ProLiant Self Solve. • Click here for Creating and Managing Hard Drive Online Spare Technology. • Click here for 17xx Power-On Self-Test (POST) Errors and fixes. • Click here for HP Dynamic Smart Array RAID Controller User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Servers User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Gen9 Servers User Guide. • Click here for Configuring Arrays on HP Smart Array Controllers Reference Guide. • Click here for Array Configuration, Diagnostic, Storage Administrator and SmartSSD Wear Gauge Utility Software and User Guides.
Feb 15, 2017 | HP Computers & Internet
Can I buy a rebuild kit for a Volfenhag 12 it is the 2500W version of the ZX-4812DVX. I need a new top everything else works I believe?
try looking for mfg name, place where they were made, state or country, zip code, part numbers, any information here is a website
that may help:
www.alltheinternet.com/
www.thesearchenginelist.com/
www.infolinks.com/
www.searchfiles.org
www.wikipedia.org/
www.wiki.org/
www.hackipedia.org/
/rebuild power inverters 2500 watts
/volfenhag 12 manufacture+service+rebuild
/repair+fix ZX-4812DVX
Mar 13, 2015 | Volfenhag Car Audio & Video
The crank shaft bearng not soft in short time needs rebuild
ask again.
did you mean that your crank bearings keep failing.?
and if so which one, there is more than one.
state true car model Suzuki dont make jeeps , sorry,
only, Fiat makes them now. "old Chrysler"
Apr 05, 2013 | Suzuki Cars & Trucks
At what stores can I buy office desks in the United States?
Hi, You can buy office desks from any online store or nearby store. But I think you should only for the store, who have the latest furniture with technology features.
As modern furniture are made to rectify the issues and quality problems faced by peoples previously.
I would like to recommend you SMARTdesks, For collaborative furniture online and go through their products, to find the one that fits your requirement. Here I have posted some products of them.
Jul 25, 2012 | Furniture
It pulls to the left when braking
check right front caliper probably frozen in place thats why the left front is pulling . Easy repair jack up right front tire and remove wheel put a jack stand under car after jacking it up for safety. remove caliper and replace also replace pads and left front caliper also when one fails the other is soon behind in failing. Parts should be under $100 for pads and both calipers. Do Not try to rebuild the old ones leave this for the rebuild shops.
Jun 20, 2012 | 1999 Chevrolet Express
My son's weedeater Model# MX550 doesn"t have a manual and he needs one to be able to rebuild or clean the carburator, as he left gasoline in it over last winter.
This is as easy as 1, 2, 3.
1. The weedeater manual for this machine will not tell him how to clean and rebuild a carburetor.
2. There are good videos on youtube for clean and rebuild of two cycle carburetors.
3. Using the brand and model number you will be able to get a carburetor rebuild kit for less than ten dollars I think from a local small engine repair and repair parts shop.
I hope this is helpful for you.
Sep 01, 2011 | Poulan Garden
What should I copy/import from old HDD to rebuild all MS Outlook?
I am not sure whether you are going to have those, any way look for windows and program files, they may contain its settings and more thing if you had concept of "server routing path", then don't worry specify your "routing path" to access the previous one and check it your contacts regarding existence and have fine
Dec 11, 2009 | Microsoft Outlook 2003 for PC
Need new or rebuild mobo heat ha desoldered dc
you should be able to order a new motherboard from this site.
http://laptopparts.vivotechnology.net/items/item.aspx?itemid=1275946
they carry that motherboard.
i don't know if you're asking us how to build it or if you're looking for that part.
in that case, if you have any questions, let me know.
Oct 17, 2009 | Computers & Internet
We just got a 6 quart kitchenaid mixer, we have used it once and the loud high pitched sound is very irritating. Is this a problem that will go away in a short time, or do we send it back for repairs? Our...
Hi Wayne. If you want to keep the mixer, you'll have to buy some earplugs. Newer Kitchenaid mixers are all that noisy. The best thing that I can say about them, is that they've got great paint jobs. If you do keep the mixer, other revelations may occur later when the plastic transmission housing fails and possibly ruins your mixer. These units are poorly manufactured in my opinion. I know because I've been through my own Kitchenaid mixer rebuild. I recommend that you return it and consider an Electrolux DLX. My own solution was to buy a used commercial Hobart mixer and rebuild it. I am once again a happy man!
Good luck! ricardok45
Apr 20, 2009 | KitchenAid KP2671 Professional 6 Series...
ASUS A7S333 Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
