Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Red light stays on
The red light came on and I cleaned the unit thoroughly and but the grid
back in and the red light did not go out. I unplugged the unit
overnight
and it still didn't go out it. and the red light still came back on.
Help I can't go without it. It really helps with my allergies.
I had the same problem: Had cleaned it inside, taking off both grids, washing wire, etc. Still the red light blinking would come back on after a few minutes. So here's what I did next:
Take off the grids on both sides. Make sure the grids are clean with water and paper towels (lots of black) On the unit itself, wipe out the metal sides and all the plastic. Then, here's the KEY,
get out your computer cleaning canned AIR and blow it into the open unit and blow the air on both of the grids too. I first used a hairdryer to blow it out, but the canned air is much stronger and I got all kinds of little black particles out with it.
Put it up and down 3 times, plugged it back in and WALAA! The unit is back to working perfectly and no red light has come on again!
I'm sure this will work for everyone if you just get the canned air and blow out the unit and the grids too even though you've cleaned them!
Posted on Sep 14, 2008
I HAVE 2 IONIC BREEZE QUADRA. FIRST HAD PROBLEM WITH 1, NOW THE SECOND ONE HAS SAME PROBLEM. HAVE CLEANED AND DRIED THOROUGHLY THE BARS AND FILTER, AND CLEANED REST OF WIRES WITH BRUSH. WHEN I TURN ON I...
If none of the hi voltage grid wires have broken then check to be sure grid wires are truly cleaned.
If not cleaned in a while like every 2 weeks they will have carbon build on them. And from my experiences with cleaning them is the build looks similar to the color of the wire. Try some qtips dipped in alcohol or cotton balls. The build comes off like flaking metal. Also be very tender with these wires they break fairly easy. When done cleaning turn upside down and back so beads can scrape up and down on wires. Also you do know once clean the parts especially the big collection bars they need to dry for at leased 24 hours before ever powering unit back on. Hope this helps.
Dec 13, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
The unit pops periodically. I have cleaned it and used an electronic duster (compressed air) but unit still pops.
i have the same unit. clean the corona wires very gently with light grade sandpaper and scrub the metal grid blades thoroughly with a scotch brite pad. my unit was sparking like a lightening storm. after i cleaned it this way it runs perfectly.
Jun 19, 2010 | Sharper Image Hybrid GP (SI724) Air...
Sharper Image Midi S1853 / NO BREEZE
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Jan 12, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
I have the Ionic Breeze Hybrid GP from Sharper Image. It has an "arching" problem in the lower section of the grid. Can this be fixed? How? The unit goes into "drying" mode and the fans still run, but I...
had the same problem, sparking in the lower section. i cleaned the grid blades on the filter with a scotch brite pad thoroughly in the area that was sparking and cleaned the corona wires inside the back of the unit gently by rubbing with light grade sandpaper. the unit runs like new. give it a try.
Nov 27, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Feb 22, 2009 | Sharper Image Ionic Breeze 3.0 Air...
My Sharper Image ionizer after I cleaned the grid now makes popping noises and then the red light that says drying grid comes on most of the time. Sometimes the light that says attention required comes...
You are probably aware that the ionizer uses a very high voltage (at very low current) to function. If you have used a cleaner of some kind on it, you could have made the grid sensitive to moisture.
I would remove the grid again and wash it thoroughly in distilled water to remove any residue that stayed behind, then dry it in warm air before reinstalling it.
Oct 10, 2008 | Sharper Image Hybrid GP (SI724) Air...
"clean" light
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Jul 31, 2008 | Sharper Image Professional Plus Ionic...
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
514 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
