Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Side by Side refrigerator (7 yrs old) cabinet not cooling down
I have had service come out twice and they have not fixed the problem. The cabinet seems to work sporadically. When i call for service it is not working and once they show up, it is. The last thing he did was put a "shim kit" in as they thought the defroster was building up moisture freezing the dampers closed. However he did not see much buildup of ice. They called Kitchenaid techincal support and this is what they were told to do. I am at a loss (apparently so are they) and cannot afford a new fridge right now. Is it possible the thermocouple is not working properly?
    Problem Solver:
  • 18 Answers
Assuming the condenser coils are really clean, and the condenser fan is working , and the cardboard panel is in place on the back of the fridge, ( yes it has to be there to direct air across the condenser coils), and the compressor is functioning properly, and the condensate drain is open. Then you should check that the evaporator fan is lubricated and running correctly, they will get sticky and not restart after every defrost.
Posted on Sep 09, 2008
I have a kitchaide side by siide refrigerator 7 yrs old. i have been noticing burning smell coming from refrigerator (not inside) when i walk by refrigrerator it smells like burnt wires burning. i dont...
Just went through the same thing only with a water leak also. The root of the issue was a computer board which shut down a cooling fan which is supposed to cool the compressor. A repair technician stated the warning signs are a constantly running unit and the center divider between the freezer and refrigerator is hot to the touch. As far as the smell and water leak. The waterline was laying against the compressor which registered at 174 degrees which melted the line and caused the leak. I guess your compressor could just be very hot also.
This line was after the valve so the only time it leaked was when the ice maker refills or one dispenses water. Access is easy pull unit out and remove lower panel on rear of unit. fan , compressor and line all visible At first he thought it was just a cooling fan but after further testing found it was a control board. The big problem is this causes a small unnoticeable water leak which over time does a great job at damaging wood floors, etc. Short term fix while waiting for parts is to shut off water and place a small fan pointed at compressor, this did reduce temp of divider and now it doesn't run 24/7.
Good Luck
Nov 17, 2010 | KitchenAid Superba Architect KSCS25INSS...
We purchased a new KitchenAid Side by Side Refrigerator Model # KSRG25FVBL01 that makes a loud knocking noise accompanied by rattling from the date we purchsed. We are getting runaround in getting it fixed...
The knocking noises heard from the Freon moving through the sealed system are perfectly normal and usually do not last long. Since the evaporator coil is mounted in the freezer section, the noise is usually louder there. Some people say it sounds like marbles knocking together.
Refrigerant (Freon) moving through the system can cause a vibration/rattling, especially as the compressor first starts up.
  1. Vibrating from top of cabinet Remove, rearrange or pad any stored items atop the refrigerator such as houseplants, coins, pens, etc.
  2. Vibrating from back or sides of refrigerator Move refrigerator away from water line in the rear or away from walls / cabinets along the side of the cabinet. Refrigerators with a static condenser on the back require a rear clearance of 3 inches across the top of the condenser.
  3. Vibrating from the bottom of refrigerator Level refrigerator so all 4 rollers / feet rest solidly on the floor.
    Hope this works.....
May 01, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker will not make ice. everything in installed properly. unit is 7 years old. red light flashes twice, then pauses and flashes twice again.
in the door ice storage. this is complicated. might check at the bottom of ref. there is a removable toe panel and on the back of the toe panel usually there is wiring diagram & mini manual to help diagnose icemaker problems.
Jan 03, 2010 | KitchenAid KSSS36QK Side by Side...
Power on but not cooling
mostly either compressor or relay is bad. replace relay and see if it works, since that is cheaper part..
Jan 03, 2010 | Frigidaire FRS23KF7AB Side by Side...
I would not advise using bleach. I would disconnect the pipe from both ends and blow down it, either by mouth or air gun to ensure of no blockages. You should poor away at least 10 cups of water after changing filter to ensure clean fresh water.
Dec 15, 2009 | KitchenAid Superba KSRG25FK Side by Side...
KSBP25FJSS01 refrig too warm, freezer working properly but fridge not cooling like it used to. 8 yrs old
Be sure it is not overfilled. There is a circulation fan in the refrigerator compartment that if it is not operating properly or blocked, will cause what you describe.
Good Luck,
Nov 29, 2009 | KitchenAid KSBP25IN Side by Side...
Our KSR25RSMSO1 is not working. The freezer is too cold, and the refrigerator is too hot.
May sound a silly question but has someone adjusted the fridge thinking it was the freezer and vice versa ?? I hava an Amana and have to think twice which symbol is fridge and which is freezer.
Usually the main won't go problem with fridges is.. the fridge part is cool but the freezer won't freeze. This indicates a refrigerant leak or compessor problem - all which require a service call to fix..
Nov 07, 2009 | KitchenAid KSRG25FK Side by Side...
Refrigerator is not cooling
If you have the setting on very cold and it is not very cold then it should be the thermostat control, unless this is over 7 yrs old, around
there, not exactly 7.
Then it might need to be recharged. I tried to locate the control part,
but the model # you posted does not work.
Mar 22, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ktichenaid, freezer on top
make sure your compressor is running if is not and and is just humming then is just your overload since you had a power outage it might off tripped it just repl and try that
Nov 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kssp42qhwoo(7 yrs old)
make sure light is turning off when door is shut
Jan 06, 2008 | KitchenAid KSRA25ILSS Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
181 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
