FrancisFrancis! FrancisFrancis! X5 Espresso Machine
Problem for FrancisFrancis! FrancisFrancis! X5 Espresso Machine
Boiler dying
By alexismaster on Sep 02, 2008
Boiler dying
Comments:
Sep 10, 2008
- Spants, You and I do have the same machine. If the boiler is still heating, what exactly needs replacement? Is it the coils that corroded on the Saeco heating element, item 188150351, that you referred to in the other post? Or is there some other part that corroded? I really appreciate your help and advice. Thanks very much for sharing.
Best Solution
posted on Sep 06, 2008
Helpful)
Spants
Rank: Guide
Rating: 92%, 22 votes
Use caution - assuming yours is the same as my design, your (very) minimal description may mean that your heating element is corroded through to the water in the boiler, and still functioning only by completing the circuit through your machine's ground wire. Low power results because you're getting a high-resistance return path, only "connecting" to the remaining portion of the heating element, and going through fresh water, which isn't that good of a conductor. The machine's metal case becomes the return path for the heating power, and the thermostat becomes irrelevant in this situation - the only thing preventing a meltdown is a cheesy little snap-disc temp cutout.
If you're comfortable with some live electrical work, the quickest (NOTE: momentarily hazardous!) test for this would be to use a three-to-two-wire "grounding adapter" on your plug, so you'd deliberately be taking OUT that ground path. The idea is to remove the ground ONLY momentarily, then use a test-light or voltmeter to check between any shiny metal part of the case and a good ground, like your water pipe or faucet. If that test-light glows, the element has indeed burned through.
Replacement ain't easy - and the original part is not sold to consumers, so you'd have to send the machine in for repairs - very expensive, to the point where it's not likely to be worthwhile, I expect. See related post on using a Saeco element to replace it if you're game.
Is this a crappy design? YES. Crappy at least in the sense that it's dangerous. But hey, it looks cool, and that's the important thing.
Was this helpful?
Yes
No
Popular Solutions for FrancisFrancis!
Questions and Unsolved Problems for FrancisFrancis!
Do you recommend FrancisFrancis! FrancisFrancis! X5 Espresso Machine?
Answer
Answer
Our Francis Francis coffee machine temperature gauge has stopped working
Answer
i need to replace the power switch on my x5, it looks like i can access it through the top,i see a... (More)
Answer
I was preparing coffee today morning when all of a sudden there were sparks from the machine. After... (More)
Answer
FrancisFrancis X1 3 years old. Since this week (water in reservoir is clear) when I switch on the... (More)
Answer
My steam valve won't close fully. Maybe it needs a new valve seat, or a whole new valve? Should I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , FL
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
