Question about MagLite - Mag Charger System 110v (M) Model - RX1019
Rechargeable mag light not working .
Dropped my rechargeable maglite, it still worked for the rest of my shift. but after charging light came on and went out. changed bulb no help .checked battery 6.2v.
  • 1,263 Answers
When you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Posted on Sep 02, 2008
2 D-cell maglite bulb lights up only when I press it down after removing lense. Everything else appears to work ok
Make sure you have the MagLite bulb with the flange, it is integral to the operation of the light.
Sep 06, 2011 | MagLite Mag-Lite& Flashlight
My maglite recharable three battery light will not turn on. The battery is ok and bulb looks ok. I dropped it once. Need help.
Best thing to do is send in for warranty repair if the battery an bulb is OK. I would replace the bulb first to verify that it is OK. If it does not work then go to:
and find the nearest repair center.
Sep 25, 2010 | MagLite Mag-Lite& Flashlight
And your question is ...
Has the battery gone dead? replace it
Has the light burned out or otherwise gone dead? replace it.
Take your Mag to the hardware store and they will help you get it going.
Oct 07, 2009 | MagLite Rechargeable Flashlight System
Rechargeable maglite won't turn on.
I found out the light bulb was bad even though it looked good. Had a fine break in the filament that I couldn't see with my eyes. Pulled the light bulb part way out, put a voltage meter on the two prongs. It showed I had voltage right up to the light bulb which told me the light bulb was bad. Ordered a new one and it works.
Dec 22, 2008 | MagLite - Mag Charger System 110v (M)...
New battery
Charge it for at least 12 hrs before using and run it down every so often to get a complete charge out of it and longer battery life.
Nov 18, 2008 | MagLite - Mag Charger System 110v (M)...
Maglight Rechargeable
did you replace the switch cover? is it original? does the cover look deformed under neath?
call up the customer service 1-800-283-5562 or email if the switch or cover is defective you should be sent a new one at no charge
Oct 07, 2008 | MagLite - Mag Charger System 110v (M)...
Maglite LED. Light switch is intermittent. Have had the same issue with my 8 month old 2AA LED Maglite, don't have receipt and have tried finding a solution to get it fixed again. Lost my temper with it...
Unfortunately not, I've seen more and more of these coming back to the shop here with faults. Mostly they seem to be connection problems like yours.
Pity, MAG are excellent and have really tarnished their reputation with this LED gimmick. A lot of the customers who return their LED's to us take a traditional MAG as a replacement..
Sep 01, 2008 | Camping, Backpacking & Hiking
Unless you are using your Mag. in extreme dusty, dirty conditions, it is not necessary to take it apart for cleaning. The Mag. is sealed against dirt and moisture. Mags are about the best lite made but always remember; 'Anything man made is subject to fail and usually at the most inconvenient time.' If I knew exactly where you are at in the dissasembly I could help you reassemble it. However, barring that;
Go to;, they can help you with what ever you need.
Good luck. :)
Jan 26, 2008 | MagLite - Mag Charger System 110v (M)...
Maglite charger
Hold the maglite after 30 min charge if warm means charging , if cold no charging , test the light when so bright means very good.
Dec 25, 2007 | MagLite - Mag Charger System 110v (M)...
MagLite - Mag Charger System 110v (M) Model - RX1019 Logo
538 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
