Question about Creative Labs ZEN Vision:M Digital Media Player
The blue light is on
The blue power light is on but the zen won't turn on. any solutions
  • 3 more comments
  • gsinacola Sep 10, 2008
    I have the same problem and my pc doesn't know it's even there to redo firmware, etc.
  • Anonymous Sep 11, 2008
    my Zen vision m was playing just fine.but when I tried to turn it off it would not respond, it was frozen. it kept playing. eventually i stuck a pin in the reset area the screen showed the battery was extremely low. It shut off. when I tried to recharge it, the screen did not respond (remained black) but the blue comes on. help
  • Anonymous Sep 18, 2008
    The same **** here
  • selbyhills Sep 18, 2008
    I have the same problem, basically. I have the Creative Labs Zen Vision M, 30GB. Has worked fine for the first year. I bought a charger (non original manufacturer) that charges it from the wall. When I plugged it in, the charging symbol looked weird, but I let it go... came back an hour later, unplugged from the wall and it won't turn on at all now. Worked fine just before that. I have tried to reset with a pin in the tiny hole, but no response. I tried to charge it the "normal way" via the original manaufacturer's USB cable and my computer does not respond to it. Nothing happens. AHHH!!! Did the cord I bought to charge it from the wall fry it?! It says it was specifically for the Zen VIsion M. I realize that it was sort of a risk, but figured it would be fine. Was I wrong?! Is there a way to fix it? I don't even mind sending it in and paying a little... but if there is something else I can do?! Please HELP!!!!
  • qflutterfly Oct 01, 2008
    I was transfering a file, the unit got really hot and no all I have is the blue light on.
  • 65 Answers
Have any of you tried to put it into Recovery Mode? Put a paperclip in the Reset hole while holding the power button in the On position. Then release the paperclip and continue to hold the power button until it goes to the Recovery Mode screen. You should at this point try Format and Scan Disk/Cleanup, then Reboot. If the screen is still black at this point, there could be a hardware failure.
Click here to view my step-by-step troubleshooting guide.
Click here to send in your device for free diagnostic testing.
Posted on Sep 23, 2008
  • TheGadgetDoctor
    TheGadgetDoctor Oct 04, 2008
    Usually
    this problem is due to the firmware. If you upgrade the firmware to version
    1.62.02
    , this problem
    usually will disappear. The older firmwares have problems in recognizing the
    battery and allowing the battery to power the unit.
    Here is what you'll need to do to save your Zen: you will need a charger for
    the operation. I recommend buying a brand new charger from the Creative
    Labs website
    or a used one here,
    instead of getting an aftermarket one off Ebay. Aftermarket ones tend to cause
    problems or fail to work altogether.
    Plug
    in the wall charger and USB cable at the same time. Your Zen should power on when
    connected the charger. Once it is powered on, connect the USB cable to your
    computer.
    If your Zen does not power on when connected to the charger, your unit is dead
    and its time to replace it or get the motherboard replaced via one of the
    Repair services offered on this website.
    Download
    the firmware
    to your PC, then reboot your PC and connect the Zen via
    USB cable. Open the firmware icon to begin the download.
    If the upgrade button on the firmware window is not available, it is also time
    to replace your motherboard due to corruption of a chip on the board.
I have the same problem! >_< g*ddamnit
SOMEONE PLEEZZZZEE A SOLUTION!!!?!?
Posted on Sep 18, 2008
Creative Zen M:vision - can't turn on/off, permanent blue light
Well, i didn't charge mine over night, was listening to it in the evening while doing some chores and all of a sudden it stopped playing, Blank screen and permanent Blue light. I tried to turn if off but it didn't respond so i left it. In the morning, it went off itself (guess the battery was low). So i connected to the computer and inserted the ZEN CD. As i was exploring the CD looking for a solution, then all of a sudden the screen came up with a note "Rebuilding..." after 5 secs it came on. With all my files intact! I hope this wud be helpful, You could give it a shot, after all there's nothing to loose!
Jan 15, 2010 | Creative Labs Zen Digital Media Player
Zen wont turn on
when you put it to charge,the blue light beside the power button must blink...if thats happening,let it charge till it powers on...maybe an hour or so...
Sep 02, 2009 | Creative Labs Zen Digital Media Player
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen connected to my computer but i can't explore it
I recently charged my friends zen for him and the power was run down, the blue light u see is normal it is just recharging, just wait for about 20-30 minutes for it to charge a little and turn the power on, it will still charge.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
Blue light is on but zen wont turn on or off
on the top right of ur zen get something sharp and poke the reset button see if that works
Feb 06, 2009 | Creative Labs Zen Digital Media Player
ZEN V PLUS - BLANK SCREEN - BLUE LIGHTS ON WONT SWITCH OFF
plug into computer
press reset butten
make use of the warenty that came with it
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision m
Zen V is dead
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
My mp3 player wont work
ok! easy solution for you^^ 1) Make sure your Zen is powered OFF. if the blue light is on and won't turn off, here's what you do: set the hold button at the top of the player to the ORANGE position, then hold your power button for 3 seconds. the keypad will flash and your player will power down. 2) push in the reset button with a pin or other fine implement. the reset button is located on the bottom of the unit, right next to the connector. your player should power up as normal now. charge it fully! your computer should be able to read it during it's charge as long as you leave it powered on^^ I hope this helps you^^
Mar 25, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
99 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
