Question about Garmin nuvi 200W GPS Receiver
Garmin nuvi 260w not operating while plugged in
This was your solution
If you are trying to use your unit in the car via the USB port and not the supplied cable, it will not work. You must use the bracket that came with the unit or the specific charger that came with the unit. The pins in the Garmin USB charger only use two pins whereas a regular charge cable uses 4.
Now i have the same problem with my nuvi 260. I am using the charger it came with. when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device so i am not sure what to do
thanks
  • Horsmn67 Oct 11, 2008
    I'm having the same problum how can I fix it
  • Garmin Expert
  • 343 Answers
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Posted on Jan 18, 2010
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
Updating maps
unit unit Off
plug unit into computer using the usb cable
go to www.MyGarmin.com register for free and update maps and firmware
Jun 26, 2010 | Garmin nuvi 260W GPS Receiver
I just bought a Garmin 265WT. I ran the registration program, but the computer does not recognize the Nuvi. I've checked My Computer and it does not show a new drive ( the Nuvi should like like a drive...
Try these steps:-
  • Unplug the USB cable from the computer.
  • Turn the unit off and then back on again.
  • Plug the USB cable into your computer.
  • The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
Also, in some cases the operating system does not support the device. Try upgrading it to the next higher level. In most of the cases windows Xp service pack 2 does not recognise this Garmin device. Try upgrading it to service pack 3.
If you are still experiencing the problem then you will need to contact Garmin for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 12, 2010 | Garmin nuvi 260W GPS Receiver
Where is the usb port on the unit to plug into my computer? dont see one
You have to have a mini usb to usb connecter. the small port on the back, the charging port acts as the usb port. unfortunatly they don't come with one.
May 12, 2010 | Garmin nuvi 260W GPS Receiver
It's on the back... its a mini-USB port, not a standard USB port. You have to use a mini-USB to USB cable.
- Jim
SHARCNET-USA
Mar 20, 2010 | Garmin nuvi 260W GPS Receiver
Problem with Garmin Nuvi 260w
No because the date recorded in the unit would have been set via satellite and cannot be changed.
Jan 08, 2010 | Garmin nuvi 260W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Jun 01, 2009 | Garmin nuvi 260W GPS Receiver
Aug 14, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
626 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
