Question about Linksys Wireless-G WRT54G Router
I have a linksys wireless-g wrt54g router which will not transmit the internet.if i remove the ethernet cable from the router and plug it straight into my pc it will log on to the iternet.when the router is connected correctley i have a full stength signal on my laptop but no internet and no internet on my pc.i have not changed any settings it was working one then not the next.i have tried every thing i know,could the router gone faulty is about 2 years old ?.
  • Anonymous Sep 04, 2008
    I have the same problem.
    When I hook up my router it works for signal
    then cuts back off and says no connection
    but if I hook directly up to my pc it works
  • Roberta Smith
    Roberta Smith May 11, 2010
    when you are getting a signal from the router that is only the router ... not an indication of how well you are connected to the internet.
    you need to log into your router and check the settings again. have you made any changes recently to your computer or router ?
    Robert
  • 66 Answers
Hi sir....try to reset the router then reconfigure it again...
Posted on Sep 02, 2008
  • Linksys Master
  • 6,487 Answers
The router only needs some reconfiguration and its still not bad, since you're having prblem with it and since the router is still under Linksys warranty better call them so one of their tech support will be able to walk you through in making this router work again, This is the number for Linksys 800-3267114 you can call them any time of the day...
Hope that helps.............
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router...
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
How to set up wep security on a linksys router that was already set up with no password it is a linksys wrt54g on lrouter a dsl network
Hi
Begin setup of your Linksys Wireless Router by first plugging in the power. Give it 10 seconds or so to initialize and then plug an ethernet cable into your wall jack and into the port on the back of the router marked Internet. Next get another ethernet cable and plug one end into your laptop and the other into one of the ports labeled 1-4 on the router. Your computer is now properly connected to the router to begin its setup and configuration.
thanks & rgds
Jul 13, 2010 | Linksys Wireless-G WRT54G Router
Linksys Wirelss Router-G problem
Hi. I would suggest that you chane the cross cable into a straight cable configuration, so that both router can transmit signal at the same time and might solve the issue of intermitent connection failure. Hope this Helps
Jun 04, 2010 | Linksys Wireless-G WRT54G Router
Wrt54gs router works on wired desktop,and wirelessly on laptop but not older laptop. if I plug in ethernet, I get internet just can't get wireless to work.
could be that the router is transmitting G or N but the old laptop is only B.
Router needs to be set to transmit B as well as G/N but be aware that this affects the performance of the newer laptop. It won't affect the desktop though.
Aug 13, 2009 | Linksys Wireless-G WRT54G Router
Trying to get my verizon dsl to link with my linksys WRT54G route
The ethernet cable needs to be run from the dsl modem to the plug marked "internet" on the back of the router.
Apr 05, 2009 | Linksys Wireless-G WRT54G Router
Why does this keep happening??? Please advise...
Your modem is set to only allow one main IP address, which it assigned to your laptop.
Connect the cables through the router, then unplug first the modem, then the router.
Wait 45 seconds, then plug in router, wait 5 seconds, then plug in modem.
Give it a few seconds to talk to everything, and you should be good to go.
Dec 04, 2008 | Linksys Wireless-G WRT54G Router
MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Dec 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Not enough ethernet ports
I have this router, you do not need two ports for your pc.
one port marked internet goes into your modem then the other ports marked 1-4 goes into your pc. it doesnt matter what one you plug it into. heres a little diagram
MODEM---------> LINKSYS ROUTER ------------> PC ethernet port.
(note: the cable from the modem to router and router to pc is a straight through cable, AKA Patch Cable. )
Feb 04, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
54 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
