So Simple and easy solution is just go on mobile reapairing shop and say there to reset your mobile phone factory settings,by using any nokia flash Device,remember nokia deafult code is 12345 if its change then its not work on your cell phone.and if you will solve this solution at home .please try this code *#7370# and 12345
i cant disable the lock code. whenever im inserting the lock code it says code error. but it can take new lock code but dont work. what is the solution?
open the pad and clean its contacts. below is the proceedure to open the phone (if it is not under warranty). you two credit cards and a screw driver.
1- Take front faceplate off by inserting card 1 between housing and silver key. As you pull up, take card 2 and slide it on the side of the phone prying the clips off. 2- Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen. 3- Slip the little black frame off of the LCD screen, and lift the screen. You should now see a screw. Removing this screw removes the back cover. 4- That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
stil i cant repair my n 73 keypad not working
key pad not working
key pad is not working
keys 1, 5 and 6 not workin, everything else is fine,
any ideas ?
